lowbat and sensorfail
Posted: Sun Jan 30, 2011 7:02 pm
by Stachi
Hello everybody
In the meteohub-manual there are described two dimensions
○ "lowbat" zeigt eine niedrige Batteriespannung des Sensors an (Wert 1)
and
○ "sensorfail" zeigt an, dass von dem Sensor seit mindestens 30 Minuten kein Signal mehr empfangen wurde.
Does anybody knows, how i can reach the values? At me, there are no values to see on Port 5558 for this dimensions (Vantage).
Thanks for any help.
Greets, Stachi
Re: lowbat and sensorfail
Posted: Sun Jan 30, 2011 8:26 pm
values just appear, when condition is met.
Posted: Sun Jan 30, 2011 8:32 pm
by Stachi
Thanks Boris
What i don't understand: the values are written in the XML just if there is a fault and in normal case there are'nt in the XML. Now: How can i check this values in php?
Are this values than for each sensor like
actual_sol0_sensorfail
actual_th0_sensorfail
actual_uv0_sensorfail
actual_sol0_lowbat
actual_th0_lowbat
actual_uv0_lowbat
Posted: Mon Jan 31, 2011 9:35 pm
by Stachi
i read the values now like this:
<actual_rain0_sensorfail>[actual_rain0_sensorfail]</actual_rain0_sensorfail>
<actual_sol0_sensorfail>[actual_sol0_sensorfail]</actual_sol0_sensorfail>
<actual_th0_sensorfail>[actual_th0_sensorfail]</actual_th0_sensorfail>
<actual_thb0_sensorfail>[actual_thb0_sensorfail]</actual_thb0_sensorfail>
<actual_uv0_sensorfail>[actual_uv0_sensorfail]</actual_uv0_sensorfail>
<actual_wind0_sensorfail>[actual_wind0_sensorfail]</actual_wind0_sensorfail>
<actual_rain0_lowbat>[actual_rain0_lowbat]</actual_rain0_lowbat>
<actual_sol0_lowbat>[actual_sol0_lowbat]</actual_sol0_lowbat>
<actual_th0_lowbat>[actual_th0_lowbat]</actual_th0_lowbat>
<actual_thb0_lowbat>[actual_thb0_lowbat]</actual_thb0_lowbat>
<actual_uv0_lowbat>[actual_uv0_lowbat]</actual_uv0_lowbat>
<actual_wind0_lowbat>[actual_wind0_lowbat]</actual_wind0_lowbat>
Is that correct? Thanks!
Posted: Sun Mar 27, 2011 11:14 am
by Kalle
Hallo Boris,
habe das ganze genauso umgesetzt wie Stachi.
Da ich kurz vor einem Stationswechsel stehe bin ich in der glücklichen Lage dieses auch zu testen, ohne den Livebetrieb der Station zu gefährden.
Also kurzerhand mal einen Sensor der Station stromlos gemacht. Leider auch nach über einer Stunde noch keine Variable in der XML zu sehen.
Nach ca. 2 Std. kam lediglich von meteohub die Mail das der Sensor ausgefallen war.
Ich denke hier besteht auf jeden Fall Nachbesserungsbedarf für diese Funktion.
Viele Grüße,
Kalle
Posted: Mon Apr 04, 2011 9:54 pm
by Stachi
Hallo Kalle
Ich hatte mittlerweile bereits auch Anfragen von anderen Usern, welche auch diverse Versuche gemacht haben. Leider auch ohne Erfolg. Leider scheint dieses Thema nicht von Interesse zu sein.
Grüsse, Stachi
Posted: Fri Sep 09, 2011 11:51 am
by Kalle
Gibt es zu diesem Thema inzwischen was neues?
Gruß,
Kalle
