Timesnchronisation
Posted: Tue Mar 08, 2011 11:11 am
by bubulino
Good Morning
Is there a possibility, to synchronize the Console-Time with the meteoplug/meteohub ?
Perhaps: "Synchronize once a day, push time to Davis Console" ?
Problem: Console with a unstable clock (runs away).
Thanks for your infos
markus
Re: Timesnchronisation
Posted: Tue Mar 08, 2011 1:02 pm
by wfpost
technically it seems possible, but Boris never replied what he thinks about implementing it ...
viewtopic.php?f=16&t=3612
wfpost wrote:yep, seems to be the case - would be a nice feature, if meteohub could keep VP2s clock in line.
from Vantage Pro and Vantage Pro2 Serial Communication Reference Manual
Page 18 of 52
"SETTIME"
It sets the time and date on the console. Data in a binary format is sent after ACK.
The data is 6 bytes plus a 2 bytes of CRC. The each field is one byte. The fields, in order,
are: seconds, minutes, hour (24 hour format), day, month, year – 1900. See section XI for
more information on calculating CRC values.
Example (to set 3:27:00 pm, June 4, 2003):
>"SETTIME"<LF>
<<ACK>
><0><27><15><4><6><103><2 Bytes of CRC>
<<ACK>
"GETTIME"
It retrieves the current time and date on the console. Data is sent in a binary format.
The format is the same as the SETTIME command.
Example (Vantage responds with 5:17:42 am, January 28, 1998):
>"GETTIME"<LF>
<<ACK>
><42><17><5><28><1><98><2 Bytes of CRC>
