Data Upload to Weatherbug Error
Posted: Sun Mar 20, 2011 7:31 pm
				Greetings,
I have completed installation of Meteohub on a SheevaPlug and most everything seems to be working fine, except for frequent errors uploading data to Weatherbug. Meteohub is set to send data to Weatherbug every 5 minutes, or 12 times per hour. When it works, Weatherbug data properly appears on their web site for my station. While Meteohub ran overnight, I received the following email error 5 or 6 times (out of 12) every hour:
subject: Meteohub (meteoplug): Cannot connect to Weather Network "No data upload to weather networks as sensor selected on weather network page for outdoor temp, outdoor humidity or outdoor dewpoint is not providing recent data."
The Davis Vantage Pro2 (6163 wireless) has a serial data logger with a serial-USB converter to connect to the PC or to the SheevaPlug. Sensor signal strength to the Vantage console is strong, and no sensor data errors are reported by the console. Data from the Davis Vantage Pro 2 seems to be OK when connected to the USB port of a PC running Weatherlink, but when connected to the SheevaPlug, these errors appear. Moving the location of the Vantage console or the Sheevaplug does not seem to make any difference.
Meteohub Time synchronizes properly, and I was able to upgrade from 4.7 to 4.7b, 4.7c, & 4.7d using the internet connection without difficulty, so it appears the internet connection is solid.
Tomorrow, I will plan to buy a snap-on ferrite for the USB cable, as other in this forum have suggested.
Is there anything else I may try?
-Bill
-Bill
