Update 4.8i
Posted: Sat Dec 03, 2011 1:22 am
Update to Meteohub V4.8i (NSLU2, x86, SheevaPlug, DreamPlug, iConnect) brings these features:
  • Makes Lufft WS600 implementation ANACON aware. Adding a "+" behind the device specification indicates that an ANACON device is added to the WS600 and Solar data could be requested from it. Using the "+" without an attached ANACON will block reading data from WS600 at all, as ANACON initialization will not succeed and will stall WS600 logging process.
  • Fixed a bug in HW watchdog function of iConnect platform (watchdog did never fire before).
  • Fixed an integer overrun bug when computing averages of air pressure data over a large time frame.
  • Adds LED support for iConnect platform. LED over USB port indicates if connected USB device has been correctly detected (LED shines on success, fades when device is disconnected or cannot be handled).
  • Adds a short LED burst on iConnect platfom (right most LED over the front button) for every single sensor data being received and mapped to an ID.
  • Adds support for Fjord Technology USB data logger.
Update Link: http://www.meteohub.de/files/update-v4.8i.upd
