username password not accepted
Posted: Sat Dec 17, 2011 11:40 am
by dhz
Installed on my Alix 3D2: image.bin (extracted from the generated USB stcik image file) Installation ends with a failure at some 99.7% cannot write to a specific block. I assume the imagefile (3.99Gb) has occupied more blocks than my CF card holds. So I just boot the thing.
Yes! I can reach it. /cgi-bin asks for a username (root) & password (meteohub) :( that combination is not being accepted.
Tried other browser, other PC, no result.
Can anyone help me with this?
Re: username password not accepted
Posted: Sat Dec 17, 2011 1:11 pm
As explained in the manual the http login is user "meteohub", password "meteohub".
Posted: Sat Dec 17, 2011 5:59 pm
by dhz
Thank you so much, it works!
As of the installation doc V4.3 Chapter 1.2.7 Following the installation flow at the end the remark states "root" as username. But that probably is used for an other system.
Now I am logged in and facing:
Demo Version has timed out. You need an activation code for further operation (System-ID: 3kBrSaA1).
Terms of the license have to be accepted once before Meteohub can be used.
I didn't even begin :roll:
Well I thought I read that demo mode use was extendend through 2012 ???? Or am I wrong?
I first would like to test the software before purchasing a license.
Is is possible to extend the demo.
Thanks in advance for your help.
Posted: Sat Dec 17, 2011 6:28 pm
root/meteohub are the credentials for ssh login, meteohub/meteohub for http login.
Just update to most recent version with function "update (auto)" get your evaluation period.
Posted: Sat Dec 17, 2011 7:14 pm
by dhz
Ah, thanks! Update installed. All at a glance. Now I can go expierence the capabilities of Meteohub.
passwords issue is also clear now. It's been so long since I was into ssh :) I've got to work my way into unix again. Well, weekend has only just begun :wink:
Thanks for the help and enjoy your weekend.
