iConnect setup
Posted: Sat Jan 14, 2012 2:21 pm
by markhiseman
In the iConnect setup instructions here: http://www.smartbedded.com/wiki/index.p ... nect_Setup
Step 3 (Patch the iConnect):
Point 1 says "Completely disconnect the iConnect (power, ethernet, USB devices) ..."
Point 7 says "About one minute after successfull boot, Meteohub will signal the IP it has received ..."
... but the ethernet is still disconnected at this point. When is it safe to reconnect the ethernet?
Mark.
Re: iConnect setup
Posted: Sat Jan 14, 2012 7:05 pm
Hi step one is not correct. It should read:
# Completely disconnect the iConnect (power, USB devices) and connect the created Meteohub USB stick to one of the four USB ports and connect the ethernet cable of your LAN/router.
