Collect data from KWh-meter in fusebox
Posted: Wed Jan 25, 2012 7:32 pm
by Hubb-er
Modern KWh-meters in your fusebox have an ir-led that flashes n- numbers of times every kWh.
Can this be read by an ir-sensing device and feed to the meteohub-logging software, so meteohub can display a grahp telling how much power your house is using?
Re: Collect data from KWh-meter in fusebox
Posted: Wed Jan 25, 2012 11:01 pm
by Aussie101
Might be worth checking out the Current Cost EnviR and their OptiSmart device to see if it is compatible with your meter.
http://www.currentcost.com/product-optismart.html
This post should really be in the 'other stations' section of the forum: viewforum.php?f=24
