version number is not updated ** solved **
Posted: Sun Jan 13, 2008 5:59 am
by giantmr4
When the meteohub is upgraded to version 1.7 under \"Maintenance\" page and after re-boot, I find the \"system info\" page still shows version 1.6.
Linux/SlugOS: 2.6.16
MeteoHub: Version 1.6 (c)2007 by Boris Pasternak,
info@meteohub.de
Pls help.:unsure:
Re:version number is not updated
Posted: Sun Jan 13, 2008 12:48 pm
this is a clear indicator that the update didn't work. We have two options from here.
1) try again with firefox.
2) put the update file on the pc-network share \"transfer\" of Meteohub and make use of the \"file update function\". This is the one below the web update funtion. as path type in \"/data/transfer/update-v1.7.upd\".
Now Meteohub should install fine and reboot.
Posted: Sun Jan 13, 2008 12:56 pm
by giantmr4
Perhaps I am using IE so the web interface upload and install does not work. :dry:
I try the second option to put the update file into /data/transfer. It works. Now Meteohub is upgraded to version 1.7 :)
Thx.
