Davis barometer and CWOP
Posted: Thu May 10, 2012 8:22 pm
What is the best way to set up the barometer functions of Meteohub using a Davis Vantage Pro2? It is hard to get it to match the QC profile in CWOP. If MH is set to "use reading from weather station" I can then apply directly a correction to make it accurate with QC, but then when the temperature changes significantly, the QC becomes way off again, 5-6 mb.
If you tell MH to "based on station's altitude", are you supposed to set the Davis console elevation to zero, or my actual elevation as I entered in MH? (5886 ft)
There is no information in the documentation about sea level pressure and altitude as reported to CWOP. What is the best way to set up the Davis and Meteohub to report the correct value to CWOP?
