Issue with OS rain gauge rain total being multiplied by 10
Posted: Wed Jul 18, 2012 1:41 pm
I've just recently started using Meteohub, being fed data from a new RFXCom USB transceiver (Firmware 45). Everything is working great, except the rainfall data being received from two oregon scientific rain gauges is being multiplied by a factor of 10 for some reason (one gauge is from my old WMR928NX, the other from my new WMR180 station).
Firstly, I have checked the data being received from the gauges directly with RFXmngr, and the data is perfect.. 1mm being recorded for each tip of the bucket, as shown in RFXmngr.
However for some reason, meteohub is recording 10mm from both gauges on each tip. I've temporarily corrected the issue by using the sensor calibration and multiplying the rainfall totals by 0.1, but I'm not sure why this might be happening. Here's a snippet of raw data from meteohub, demonstrating the issue:
Has anybody else experienced this issue or have any thoughts as to why this might be happening? Any thoughts most appreciated!
Cheers,
Graham
As you can see, the rainfall total is incrementing by 100 each time the bucket tips, when it should only be incrementing by 10 (1/10 mm). I've tried both gauges independently, and both behave exactly the same way, so I suspect it's something happening inside meteohub itself.20120718111437 rain0 040 0 153600
20120718111524 rain0 040 0 153600
20120718111611 rain0 040 0 153600
20120718111658 rain0 040 0 153600
20120718111745 rain0 040 0 153600
20120718111832 rain0 040 0 153600
20120718111919 rain0 020 0 153700
20120718112006 rain0 020 0 153700
20120718112052 rain0 020 0 153700
20120718112139 rain0 020 0 153700
20120718112226 rain0 020 0 153700
20120718112313 rain0 020 0 153700
20120718112400 rain0 020 0 153700
20120718112447 rain0 020 0 153700
20120718112534 rain0 020 0 153700
20120718112621 rain0 020 0 153700
20120718112708 rain0 020 0 153700
20120718112754 rain0 020 0 153700
20120718112841 rain0 020 0 153700
20120718112928 rain0 020 0 153700
20120718113015 rain0 020 0 153700
20120718113102 rain0 020 0 153700
20120718113149 rain0 020 0 153700
20120718113236 rain0 020 0 153800
20120718113323 rain0 020 0 153800
20120718113412 rain0 020 0 153800
Cheers,
Graham
