OAK Barometer problem
Posted: Fri Sep 28, 2012 9:01 am
by Manisflight
Hello
i connect a new OAK Barometer. In Wetterstation Tab is visible Toradex OAK Barometer, i add him.
But in Sensoren Tab i see also (OAK Baro) but data is empty.
Restart Meteohub and disconnect Power, unsuccessful.
Meteohub.log:
logger (27.09.2012 22:26:41): data logger (version 4.9p, build 1184) started.
logger (27.09.2012 22:26:42): station 0 (ISS direct), adapter is version "1.0".
logger (27.09.2012 22:26:42): connect station 0 (ISS direct via USB serial).
logger (27.09.2012 22:26:42): connect station 1 (OAK Baro via USB HID).
wmr928fulleval(27.09.2012 22:29:38): recomputation of weather data finished: 544744 records processed in 875 seconds (622 records per second)
logger (27.09.2012 22:34:11): no data synchronization with station 1 (OAK Baro) for 450 seconds, data logger will be restarted.
logger (27.09.2012 22:34:11): disconnect station 0 (ISS direct).
logger (27.09.2012 22:34:11): disconnect station 1 (OAK Baro).
logger (27.09.2012 22:34:12): data logger stopped.
Thank you!
Manfred
Re: OAK Barometer problem
Posted: Sat Sep 29, 2012 12:05 pm
What HW do you use? is it a DC01?
Posted: Sat Sep 29, 2012 1:15 pm
by Manisflight
Yes its a DC01
Posted: Sat Sep 29, 2012 2:51 pm
DC01 only supports USB2.0 devices. If OAK is a USB 1.x you need a USB 2.0 Hub in between. Any cheap unpowered will do.
Toradex specs for OAK say it is USB 2.0 but I doubt that. Please try with a USB HUB laying around.
What does "dmesg log" say?
Posted: Sun Sep 30, 2012 3:15 pm
by Manisflight
-e DMESG:
Linux version 2.6.31.14_dc01 (root@mars) (gcc version 4.6.3 (GCC) ) #2 SMP Thu Mar 29 14:41:08 CEST 2012
CPU: ARMv6-compatible processor [410fb025] revision 5 (ARMv7), cr=00c5387f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: Oxsemi NAS
1 memory region
Ignoring unrecognised tag 0x00000000
Memory policy: ECC disabled, Data cache writealloc
On node 0 totalpages: 32768
free_area_init_node: node 0, pgdat c0447180, node_mem_map c0469000
Normal zone: 256 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 32512 pages, LIFO batch:7
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: root=/dev/sda2 console=ttyS0,115200 elevator=cfq mac_adr=0x00,0x30,0xe0,0x00,0x00,0x01 rootwait ubi.mtd=2,512 mem=128M poweroutage=yes
PID hash table entries: 512 (order: 9, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 125212KB available (3980K code, 261K data, 128K init, 0K highmem)
Hierarchical RCU implementation.
NR_IRQS:96
OX820_RPS_init_irq: interrupts 64 to 96
Console: colour dummy device 80x30
console [ttyS0] enabled
Calibrating delay loop... 339.14 BogoMIPS (lpj=1695744)
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
Calibrating local timer... 424.49MHz.
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (678.29 BogoMIPS).
NET: Registered protocol family 16
Number of DMA channels = 4, version = 4
Reserving a DMA channel for ODRB
Allocating 645 SRAM generic DMA descriptors
bio: create slab <bio-0> at 0
SCSI subsystem initialized
libata version 3.00 loaded.
cfg80211: Calling CRDA to update world regulatory domain
NET: Registered protocol family 2
Switched to NOHz mode on CPU #0
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Switched to NOHz mode on CPU #1
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
Create fragment cache
CoPro: Programming start address as 0xd000e000
Watchdog driver registered
fuse init (API version 7.12)
SGI XFS with security attributes, large block/inode numbers, no debug enabled
msgmni has been set to 244
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x44200000 (irq = 55) is a 16550A
brd: module loaded
loop: module loaded
ox820sata: OX820 sata core.
scsi0 : oxnassata
scsi1 : oxnassata
ata1: SATA max UDMA/133 irq 50
ata2: SATA max UDMA/133 irq 50
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata1.00: ATA-8: Corsair Nova 2 SSD, 1.3.4, max UDMA/133
ata1.00: 58626288 sectors, multi 16: LBA48 NCQ (depth 0/32)
ata1.00: configured for UDMA/133
ata1: exception Emask 0x10 SAct 0x0 SErr 0x0 action 0x9 t4
ata1: EH complete
ata2: SATA link down (SStatus 0 SControl 300)
scsi 0:0:0:0: Direct-Access ATA Corsair Nova 2 S 1.3. PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 58626288 512-byte logical blocks: (30.0 GB/27.9 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
NAND device: Manufacturer ID: 0xad, Chip ID: 0xda (Hynix NAND 256MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 737 at 0x000005c20000
Bad eraseblock 1388 at 0x00000ad80000
Bad eraseblock 1402 at 0x00000af40000
sda:
Creating 2 MTD partitions on "NAND 256MiB 3,3V 8-bit":
0x000000000000-0x0000026c0000 : "Boot partition"
sda1 sda2 sda3 sda4
0x0000026c0000-0x000010000000 : "Data Partition"
mice: PS/2 mouse device common for all mice
sd 0:0:0:0: [sda] Attached SCSI disk
rtc-ds1307 0-0068: rtc core: registered m41t00 as rtc0
OXNAS bit-bash I2C driver initialisation OK
md: linear personality registered for level -1
md: raid0 personality registered for level 0
md: raid1 personality registered for level 1
device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
TCP cubic registered
NET: Registered protocol family 10
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
lib80211_crypt: registered algorithm 'NULL'
rtc-ds1307 0-0068: setting system clock to 2012-09-29 21:30:41 UTC (1348954241)
md: Waiting for all devices to be available before autodetect
md: If you don't use raid, use raid=noautodetect
md: Autodetecting RAID arrays.
md: Scanned 0 and added 0 devices.
md: autorun ...
md: ... autorun DONE.
kjournald starting. Commit interval 5 seconds
EXT3 FS on sda2, internal journal
EXT3-fs: mounted filesystem with writeback data mode.
VFS: Mounted root (ext3 filesystem) on device 8:2.
Freeing init memory: 128K
Adding 204792k swap on /dev/sda3. Priority:-1 extents:1 across:204792k SS
Probing for Synopsis GMAC, unit 0
eth0: Tuning GMAC 0 RGMII timings
initialise phy time : 1348954243
eth0: PHY is Realtek RTL8211D, type 0x001cc914
eth0: GMAC ver = 53, vendor ver = 18 at 0xed400000, IRQ 40
eth0: Found PHY at address 3, type 0x001cc914 -> 10/100/1000
eth0: Ethernet addr: 00:30:e0:00:01:05
probe() eth0: Leon x2 clock
kjournald starting. Commit interval 120 seconds
EXT3 FS on sda4, internal journal
Waiting for auto-negotiation to complete......
initialise phy time : 1348954246
CoPro offload is active on eth0
Alloc'ing ARM descs 8192 bytes
Alloc'ing CoPro parameters 40 bytes
gmac gmac.0: firmware: requesting gmac_copro_firmware
eth0: Resetting GMAC
eth0: GMAC reset complete
hw_set_mac_address() Storing port0 mac_adr in global array
eth0: Setting Rx flow control thresholds for LAN port
CoPro available SRAM end 0x00000001
Copro offload started
initialise phy time : 1348954247
eth0: link down
ADDRCONF(NETDEV_UP): eth0: link is not ready
eth0: link up, 1000Mbps, full-duplex, not using pause, lpa 0xC1E1
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
eth0: no IPv6 routers present
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Start USB clocks
oxnas-ehci oxnas-ehci.0: OXNAS EHCI Host Controller
oxnas-ehci oxnas-ehci.0: new USB bus registered, assigned bus number 1
oxnas-ehci oxnas-ehci.0: irq 39, io mem 0x00000000
oxnas-ehci oxnas-ehci.0: USB 0.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usb 1-1: new full speed USB device using oxnas-ehci and address 2
usb 1-1: configuration #1 chosen from 1 choice
generic-usb 0003:1B67:0002.0001: claimed by neither input, hiddev nor hidraw
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
usb 1-2: new full speed USB device using oxnas-ehci and address 3
usb 1-2: configuration #1 chosen from 1 choice
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for pl2303
pl2303 1-2:1.0: pl2303 converter detected
usb 1-2: pl2303 converter now attached to ttyUSB0
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
watchdog_timer_action() possible CSUM error, tx_timeout_count = 0
CSUM Watchdog triggered
GMAC:reset 1348947327
usb 1-1: USB disconnect, address 2
usb 1-1: new full speed USB device using oxnas-ehci and address 4
generic-usb 0003:1B67:0002.0002: claimed by neither input, hiddev nor hidraw
USB:
Bus 001 Device 004: ID 1b67:0002
Bus 001 Device 003: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
PCI:
Partitions:
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 1500736 885120 539380 63% /
/dev/root 1500736 885120 539380 63% /
tmpfs 62748 0 62748 0% /lib/init/rw
tmpfs 10240 48 10192 1% /dev
tmpfs 62748 0 62748 0% /dev/shm
/dev/sda4 27139240 205732 25554892 1% /data
tmpfs 8192 0 8192 0% /var/lock
tmpfs 32768 1852 30916 6% /var/run
tmpfs 32768 8 32760 1% /var/log
Process:
PID TTY STAT TIME COMMAND
1 ? Ss 0:01 init [2]
2 ? S< 0:00 [kthreadd]
3 ? S< 0:00 [migration/0]
4 ? S< 0:00 [ksoftirqd/0]
5 ? S< 0:00 [migration/1]
6 ? S< 0:00 [ksoftirqd/1]
7 ? S< 0:00 [events/0]
8 ? S< 0:04 [events/1]
9 ? S< 0:00 [khelper]
12 ? S< 0:00 [async/mgr]
81 ? S< 0:00 [kblockd/0]
82 ? S< 0:00 [kblockd/1]
87 ? S< 0:00 [ata/0]
88 ? S< 0:00 [ata/1]
89 ? S< 0:00 [ata_aux]
113 ? S 0:00 [pdflush]
114 ? S 0:00 [pdflush]
115 ? S< 0:00 [kswapd0]
116 ? S< 0:00 [aio/0]
117 ? S< 0:00 [aio/1]
119 ? S< 0:00 [xfs_mru_cache]
120 ? S< 0:00 [xfslogd/0]
121 ? S< 0:00 [xfslogd/1]
122 ? S< 0:00 [xfsdatad/0]
123 ? S< 0:00 [xfsdatad/1]
124 ? S< 0:00 [xfsconvertd/0]
125 ? S< 0:00 [xfsconvertd/1]
126 ? S< 0:00 [crypto/0]
127 ? S< 0:00 [crypto/1]
258 ? S< 0:00 [scsi_eh_0]
261 ? S< 0:00 [scsi_eh_1]
271 ? S< 0:00 [mtdblockd]
293 ? S< 0:00 [kstriped]
295 ? S< 0:00 [hwraid_eh]
302 ? S< 0:00 [kjournald]
351 ? S<s 0:00 udevd --daemon
446 ? Ss 0:00 logsave -s /var/log/fsck/checkroot fsck -C -a -t ext3 /dev/sda2
534 ? S< 0:00 [kjournald]
636 ? Ss 0:00 dhclient -v -pf /var/run/dhclient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases eth0
678 ? Ss 0:00 /sbin/portmap
690 ? Ss 0:00 /sbin/rpc.statd
754 ? S< 0:00 [khubd]
756 ? S< 0:00 udevd --daemon
808 ? S< 0:00 [usbhid_resumer]
834 ? S 0:00 /home/meteohub/iconledburst /dev/ledburst
837 ? S 0:00 /home/meteohub/meteoschedule /dev/meteohub
860 ? S< 0:00 udevd --daemon
917 ? S< 0:00 /home/meteohub/loggerd /var/run/loggerd.pid
936 ? Sl 0:06 /usr/sbin/rsyslogd -f /etc/syslog.conf
967 ? Ss 0:00 /usr/sbin/nmbd -D
986 ? Ss 0:00 /usr/sbin/smbd -D
1012 ? S 0:00 /home/meteohub/meteonet -r
1059 ? Ss 0:00 startpar -f -- samba
1060 ? Ss 0:02 /usr/sbin/cron
1065 ? Ss 0:00 /usr/bin/rsync /var/run/rsyncd.pid --daemon
1066 ? S 0:00 /usr/sbin/smbd -D
1077 ? S<s 0:00 /usr/sbin/thttpd -C /etc/thttpd.conf
1079 ? Ss 0:00 /usr/sbin/sshd
1080 ? S<s 0:00 /usr/sbin/thttpdbackup -C /etc/thttpd-backup.conf
1109 ? SLs 0:00 /usr/sbin/watchdog
1122 ttyS0 Ss+ 0:00 /sbin/getty -L ttyS0 115200 linux
1138 ? Ss 0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -u 102:104 -g
23437 ? S< 0:00 /home/meteohub/loggerd /var/run/loggerd.pid
23490 ? S< 0:00 sh -c nice -n -11 /home/meteohub/hidlog37 37 898722068893
23491 ? S< 0:00 /home/meteohub/hidlog37 37 898722068893
23492 ? Z< 0:00 [sh] <defunct>
24011 ? S 0:00 /USR/SBIN/CRON
24012 ? Ss 0:00 /bin/sh -c sleep 25; [ -z "`ls /var/run/meteohub/uploads/`" ] || [ -n "`/bin/pidof /usr/bin/ncftpput`" ] || /usr/bin/ncftpput -S .tmp -R -V -DD -u "*****" -p '*****' -P 21 ftp.***.ch meteohub /var/run/meteohub/uploads/* 2>&1 | /usr/bin/logger
24013 ? S 0:00 sleep 25
24014 ? S 0:00 /USR/SBIN/CRON
24015 ? Ss 0:00 /bin/sh -c sleep 20; [ -n "`/bin/pidof wmr928fulleval`" ] || (/srv/www/meteograph.cgi graph Rain_Today >/var/run/meteohub/Rain_Today4.png; /srv/www/cgi-bin/stamp.cgi mv "/var/run/meteohub/Rain_Today4.png" "/var/run/meteohub/uploads/Rain_Today.png")
24016 ? S 0:00 sleep 20
24017 ? S 0:00 /USR/SBIN/CRON
24018 ? Ss 0:00 /bin/sh -c sleep 15; [ -n "`/bin/pidof wmr928fulleval`" ] || (/srv/www/meteograph.cgi graph RainRate_Today >/var/run/meteohub/RainRate_Today3.png; /srv/www/cgi-bin/stamp.cgi mv "/var/run/meteohub/RainRate_Today3.png" "/var/run/meteohub/uploads/RainRate_Tody.png")
24019 ? S 0:00 sleep 15
24020 ? S 0:00 /USR/SBIN/CRON
24021 ? Ss 0:00 /bin/sh -c sleep 10; [ -n "`/bin/pidof wmr928fulleval`" ] || (/srv/www/meteograph.cgi graph Humity_Today >/var/run/meteohub/Humity_Today2.png; /srv/www/cgi-bin/stamp.cgi mv "/var/run/meteohub/Humity_Today2.png" "/var/run/meteohub/uploads/Humity_Today.png")
24022 ? S 0:00 sleep 10
24023 ? S 0:00 /USR/SBIN/CRON
24024 ? Ss 0:00 /bin/sh -c sleep 5; [ -n "`/bin/pidof wmr928fulleval`" ] || (/srv/www/meteograph.cgi graph Temp_Today >/var/run/meteohub/Temp_Today1.png; /srv/www/cgi-bin/stamp.cgi mv "/var/run/meteohub/Temp_Today1.png" "/var/run/meteohub/uploads/Temp_Today.png")
24025 ? S 0:00 sleep 5
24035 ? S 0:00 /USR/SBIN/CRON
24036 ? S 0:00 /USR/SBIN/CRON
24042 ? Ss 0:00 /bin/sh -c /bin/pidof -x histeval1 || /usr/bin/nice /home/meteohub/histeval1
24044 ? Ss 0:00 /bin/sh -c /bin/pidof -x histeval0 || /usr/bin/nice /home/meteohub/histeval0
24058 ? SN 0:00 /bin/sh /home/meteohub/histeval1
24059 ? RN 0:00 /home/meteohub/wmr928eval -c day1 -t -100000 -w /data/weather/ -s /home/meteohub/wmr928eval.conf -H
24060 ? SN 0:00 /bin/sh /home/meteohub/histeval0
24061 ? RN 0:00 /home/meteohub/wmr928eval -c min1 -t -3720 -w /data/weather/ -s /home/meteohub/wmr928eval.conf -S
24089 ? S< 0:00 meteohub.cgi
24091 ? S< 0:00 /usr/sbin/thttpd -C /etc/thttpd.conf
24120 ? Z 0:00 [watchdog] <defunct>
24124 ? R< 0:00 ps ax
Posted: Sun Sep 30, 2012 4:54 pm
I checked with a OAK Temp/Hum sensor on my DC01 and there it needs the USB hub inbetween.
Direct connection throws quite some errors in dmesg when hot-plugging the sensor.
With the hub as interconnect, it works without a flaw.
Did you try with a USB hub?
Posted: Tue Oct 02, 2012 11:47 am
by Manisflight
Yes i try now, with USB Hub its working.
Thank you!
