Thanks -- just cleared the logs and did a reboot. Here is what I get in dmesg:
DMESG:
00100000000 (reserved)
Warning only 896MB will be used.
Use a HIGHMEM enabled kernel.
896MB LOWMEM available.
found SMP MP-table at 000ff780
Entering add_active_range(0, 0, 229376) 0 entries of 256 used
Zone PFN ranges:
DMA 0 -> 4096
Normal 4096 -> 229376
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0 -> 229376
On node 0 totalpages: 229376
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 4064 pages, LIFO batch:0
Normal zone: 1760 pages used for memmap
Normal zone: 223520 pages, LIFO batch:31
Movable zone: 0 pages used for memmap
DMI present.
ACPI: RSDP 000F86D0, 0014 (r0 ACPIAM)
ACPI: RSDT 3BFC0000, 003C (r1 101608 RSDT1502 20081016 MSFT 97)
ACPI: FACP 3BFC0200, 0084 (r2 101608 FACP1502 20081016 MSFT 97)
ACPI: DSDT 3BFC0430, 3ADF (r1 1ADMY 1ADMY000 0 INTL 20051117)
ACPI: FACS 3BFCE000, 0040
ACPI: APIC 3BFC0390, 0054 (r1 101608 APIC1502 20081016 MSFT 97)
ACPI: MCFG 3BFC03F0, 003C (r1 101608 OEMMCFG 20081016 MSFT 97)
ACPI: OEMB 3BFCE040, 0071 (r1 101608 OEMB1502 20081016 MSFT 97)
ACPI: HPET 3BFC3F10, 0038 (r1 101608 VIA HPET 20081016 MSFT 97)
ACPI: SSDT 3BFCE0C0, 023A (r1 AMI P001PM 1 INTL 20051117)
ACPI: PM-Timer IO Port: 0x808
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Processor #0 6:13 APIC version 20
ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 1, version 3, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
ACPI: HPET id: 0x11068201 base: 0xfed00000
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 40000000 (gap: 3c000000:c2c00000)
swsusp: Registered nosave memory region: 000000000009f000 - 00000000000a0000
swsusp: Registered nosave memory region: 00000000000a0000 - 00000000000e0000
swsusp: Registered nosave memory region: 00000000000e0000 - 0000000000100000
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 227584
Kernel command line: root=/dev/hdc1 ro quiet
mapped APIC to ffffb000 (fee00000)
mapped IOAPIC to ffffa000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
Detected 498.755 MHz processor.
Console: colour VGA+ 80x25
console [tty0] enabled
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 901128k/917504k available (1753k kernel code, 15740k reserved, 722k data, 324k init, 0k highmem)
virtual kernel memory layout:
fixmap : 0xfffb3000 - 0xfffff000 ( 304 kB)
vmalloc : 0xf8800000 - 0xfffb1000 ( 119 MB)
lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
.init : 0xc036e000 - 0xc03bf000 ( 324 kB)
.data : 0xc02b6435 - 0xc036ade4 ( 722 kB)
.text : 0xc0100000 - 0xc02b6435 (1753 kB)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
hpet clockevent registered
Calibrating delay using timer specific routine.. 998.49 BogoMIPS (lpj=1996997)
Security Framework initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
Initializing cgroup subsys ns
Initializing cgroup subsys cpuacct
CPU: After generic identify, caps: a7c9bbff 00100000 00000000 00000000 00004181 00000000 00000000 00000000
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 128K (64 bytes/line)
CPU: After all inits, caps: 27c9bbff 00100000 00000000 00000000 00004181 0000ffcc 00000000 00000000
Compat vDSO mapped to ffffe000.
CPU: Centaur VIA Eden Processor 500MHz stepping 00
Checking 'hlt' instruction... OK.
Freeing SMP alternatives: 0k freed
ACPI: Core revision 20070126
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
net_namespace: 64 bytes
Booting paravirtualized kernel on bare hardware
NET: Registered protocol family 16
EISA bus registered
ACPI: bus type pci registered
PCI: BIOS Bug: MCFG area at e0000000 is not E820-reserved
PCI: Not using MMCONFIG.
PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=2
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: EC: Look up EC in DSDT
ACPI: Interpreter enabled
ACPI: (supports S0 S1 S3 S4 S5)
ACPI: Using IOAPIC for interrupt routing
Error attaching device data
ACPI: PCI Root Bridge [PCI0] (0000:00)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P2._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 *6 7 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
ACPI Warning (tbutils-0217): Incorrect checksum in table [OEMB] - 5D, should be 56 [20070126]
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp: PnP ACPI: found 15 devices
ACPI: ACPI bus type pnp unregistered
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
NET: Registered protocol family 8
NET: Registered protocol family 20
hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
hpet0: 3 32-bit timers, 14318180 Hz
ACPI: RTC can wake from S4
Time: tsc clocksource has been installed.
system 00:08: ioport range 0xa60-0xa61 has been reserved
system 00:08: ioport range 0xa00-0xa0f has been reserved
system 00:08: ioport range 0xa20-0xa2f has been reserved
system 00:08: ioport range 0xa10-0xa1f has been reserved
system 00:08: ioport range 0xa30-0xa3f has been reserved
system 00:08: ioport range 0xa40-0xa4f has been reserved
system 00:08: ioport range 0xa50-0xa5f has been reserved
system 00:09: ioport range 0x3e0-0x3e7 has been reserved
system 00:09: ioport range 0x4d0-0x4d1 has been reserved
system 00:09: ioport range 0x800-0x87f has been reserved
system 00:09: ioport range 0x400-0x41f has been reserved
system 00:0c: iomem range 0xfec00000-0xfec00fff could not be reserved
system 00:0c: iomem range 0xfee00000-0xfee00fff could not be reserved
system 00:0d: iomem range 0xe0000000-0xefffffff has been reserved
system 00:0e: iomem range 0x0-0x9ffff could not be reserved
system 00:0e: iomem range 0xc0000-0xcffff could not be reserved
system 00:0e: iomem range 0xe0000-0xfffff could not be reserved
system 00:0e: iomem range 0x100000-0x3bffffff could not be reserved
system 00:0e: iomem range 0xfec00000-0xffffffff could not be reserved
PCI: Bridge: 0000:00:01.0
IO window: disabled.
MEM window: fd000000-feafffff
PREFETCH window: c0000000-dfffffff
PCI: Bridge: 0000:00:13.0
MEM window: feb00000-febfffff
PREFETCH window: disabled.
PCI: Setting latency timer of device 0000:00:01.0 to 64
PCI: Setting latency timer of device 0000:00:13.0 to 64
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
checking if image is initramfs...<7>Switched to high resolution mode on CPU 0
it is
Freeing initrd memory: 4706k freed
audit: initializing netlink socket (disabled)
audit(1352236672.940:1): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
PCI: VIA PCI bridge detected. Disabling DAC.
Boot video device is 0000:01:00.0
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
hpet_resources: 0xfed00000 is busy
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:05: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:06: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
EISA: Probing bus 0 at eisa.0
EISA: Detected 0 cards.
cpuidle: using governor ladder
cpuidle: using governor menu
TCP bic registered
NET: Registered protocol family 17
Using IPI Shortcut mode
registered taskstats version 1
Freeing unused kernel memory: 324k freed
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: Processor [P001] (supports 16 throttling states)
8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
8139cp 0000:00:08.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip
8139cp 0000:00:08.0: Try the "8139too" driver instead.
8139too Fast Ethernet driver 0.9.28
ACPI: PCI Interrupt 0000:00:08.0[A] -> GSI 16 (level, low) -> IRQ 16
eth0: RealTek RTL8139 at 0xe800, 44:4d:50:06:0d:c4, IRQ 16
eth0: Identified 8139 chip type 'RTL-8100B/8139D'
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller (0x1106:0x5324 rev 0x00) at PCI slot 0000:00:0f.0
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA cx700 (rev 00) IDE UDMA133 controller on pci0000:00:0f.0
ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:pio, hdb:pio
ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:DMA, hdd:pio
Probing IDE interface ide0...
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
USB Universal Host Controller Interface driver v3.0
Probing IDE interface ide1...
hdd: IRQ probe failed (0xfffffdfc)
hdc: TS4GCF133, ATA DISK drive
hdc: host max PIO5 wanted PIO255(auto-tune) selected PIO4
hdc: host side 80-wire cable detection failed, limiting max speed to UDMA33
hdc: UDMA/33 mode selected
ide1 at 0x170-0x177,0x376 on irq 15
ACPI: PCI Interrupt 0000:00:10.0[A] -> GSI 20 (level, low) -> IRQ 17
uhci_hcd 0000:00:10.0: UHCI Host Controller
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:10.0: irq 17, io base 0x0000ec00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
SCSI subsystem initialized
ACPI: PCI Interrupt 0000:00:10.1[B] -> GSI 22 (level, low) -> IRQ 18
uhci_hcd 0000:00:10.1: UHCI Host Controller
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:10.1: irq 18, io base 0x0000e080
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
libata version 3.00 loaded.
ACPI: PCI Interrupt 0000:00:10.4[D] -> GSI 23 (level, low) -> IRQ 19
ehci_hcd 0000:00:10.4: EHCI Host Controller
ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 3
ehci_hcd 0000:00:10.4: debug port 1
ehci_hcd 0000:00:10.4: irq 19, io mem 0xfcfff400
ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 4 ports detected
hdc: max request size: 128KiB
hdc: 7831152 sectors (4009 MB) w/1KiB Cache, CHS=7769/16/63
hdc: hdc1 hdc2 hdc3
Attempting manual resume
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting. Commit interval 5 seconds
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
Linux agpgart interface v0.102
agpgart: Detected VIA CX700 chipset
agpgart: AGP aperture is 128M @ 0xf0000000
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
input: PC Speaker as /class/input/input1
input: Power Button (FF) as /class/input/input2
ACPI: Power Button (FF) [PWRF]
input: Sleep Button (CM) as /class/input/input3
ACPI: Sleep Button (CM) [SLPB]
input: Power Button (CM) as /class/input/input4
ACPI: Power Button (CM) [PWRB]
Real Time Clock Driver v1.12ac
ACPI: PCI Interrupt 0000:02:01.0[A] -> GSI 17 (level, low) -> IRQ 20
PCI: Setting latency timer of device 0000:02:01.0 to 64
parport_pc 00:07: reported by Plug and Play ACPI
parport0: PC-style at 0x378, irq 7 [PCSPP]
Adding 200804k swap on /dev/hdc2. Priority:-1 extents:1 across:200804k
EXT3 FS on hdc1, internal journal
loop: module loaded
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.12.0-ioctl (2007-10-02) initialised: dm-devel@redhat.com
EXT3 FS on hdc3, internal journal
ndiswrapper version 1.53 loaded (smp=no, preempt=no)
ndiswrapper: driver vnwl () loaded
ACPI: PCI Interrupt 0000:00:0a.0[A] -> GSI 18 (level, low) -> IRQ 21
ndiswrapper: using IRQ 21
wlan0: ethernet device 00:12:7b:48:61:83 using NDIS driver: vnwl, version: 0x1001e, NDIS version: 0x500, vendor: 'VIA Networking Solomon Wireless LAN Adapter ', 1106:3253:1106:6655.5.conf
wlan0: encryption modes supported: WEP; TKIP with WPA, WPA2, WPA2PSK; AES/CCMP with WPA, WPA2, WPA2PSK
usbcore: registered new interface driver ndiswrapper
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ADDRCONF(NETDEV_UP): wlan0: link is not ready
rtc_cmos: probe of 00:02 failed with error -16
usbcore: registered new interface driver labjacku3
/usr/src/U3/labjacku3.c: USB LabJack U3 Driver v0.32
usbcore: registered new interface driver usbserial
drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core
drivers/usb/serial/usb-serial.c: USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver
drivers/usb/serial/usb-serial.c: USB Serial support registered for cp2101
usbcore: registered new interface driver cp2101
drivers/usb/serial/cp2101.c: Silicon Labs CP2101/CP2102 RS232 serial adaptor driver v0.07
drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
eth0: no IPv6 routers present
USB:
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
PCI:
00:00.0 0600: 1106:0324 (rev 10)
00:00.1 0600: 1106:1324
00:00.2 0600: 1106:2324
00:00.3 0600: 1106:3324
00:00.4 0600: 1106:4324
00:00.7 0600: 1106:7324
00:01.0 0604: 1106:b198
00:08.0 0200: 10ec:8139 (rev 10)
00:0a.0 0280: 1106:3253
00:0f.0 0101: 1106:5324
00:10.0 0c03: 1106:3038 (rev 90)
00:10.1 0c03: 1106:3038 (rev 90)
00:10.4 0c03: 1106:3104 (rev 90)
00:11.0 0601: 1106:8324
00:11.7 0600: 1106:324e
00:13.0 0604: 1106:324b
01:00.0 0300: 1106:3157 (rev 03)
02:01.0 0403: 1106:3288 (rev 10)
Partitions:
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/hdc1 774040 523972 210712 72% /
tmpfs 453204 0 453204 0% /lib/init/rw
udev 10240 48 10192 1% /dev
tmpfs 453204 0 453204 0% /dev/shm
/dev/hdc3 2822496 328092 2351024 13% /data
tmpfs 8192 0 8192 0% /var/lock
tmpfs 16384 2740 13644 17% /var/run
tmpfs 16384 20 16364 1% /var/log
Process:
PID TTY STAT TIME COMMAND
1 ? Ss 0:03 init [2]
2 ? S< 0:00 [kthreadd]
3 ? S< 0:00 [ksoftirqd/0]
4 ? S< 0:00 [watchdog/0]
5 ? S< 0:00 [events/0]
6 ? S< 0:00 [khelper]
41 ? S< 0:00 [kblockd/0]
44 ? S< 0:00 [kacpid]
45 ? S< 0:00 [kacpi_notify]
124 ? S< 0:00 [kseriod]
156 ? S 0:00 [pdflush]
157 ? S 0:00 [pdflush]
158 ? S< 0:00 [kswapd0]
159 ? S< 0:00 [aio/0]
564 ? S< 0:00 [ksuspend_usbd]
580 ? S< 0:00 [khubd]
679 ? S< 0:00 [ata/0]
684 ? S< 0:00 [ata_aux]
887 ? S< 0:00 [kjournald]
1030 ? S<s 0:00 udevd --daemon
1638 ? S< 0:00 [ksnapd]
1694 ? S< 0:00 [kjournald]
1745 ? S< 0:00 [ntos_wq]
1746 ? S< 0:00 [ndis_wq]
1747 ? S< 0:00 [wrapndis_wq]
1850 ? Ss 0:00 /sbin/wpa_supplicant -B -P /var/run/wpa_supplicant.wlan0.pid -i wlan0 -D wext -C /var/run/wpa_supplicant
1902 ? Ss 0:00 /sbin/portmap
2153 ? S 0:00 /bin/sh /etc/rc.boot/initsensors
2154 ? S 0:00 sleep 60
2158 ? S 0:00 /home/meteohub/meteoschedule /dev/meteohub
2205 ? Ss 0:00 /sbin/syslogd
2211 ? Ss 0:00 /sbin/klogd -x
2286 ? Ss 0:00 /usr/sbin/acpid -c /etc/acpi/events -s /var/run/acpid.socket
2291 ? S<s 0:00 /home/meteohub/loggerd /var/run/loggerd.pid
2292 ? S< 0:00 /home/meteohub/loggerd /var/run/loggerd.pid
2308 ? Ss 0:00 /home/meteohub/meteonet -r
2360 ? Ss 0:00 /usr/bin/rsync /var/run/rsyncd.pid --daemon
2362 ? Ss 0:00 /usr/sbin/nmbd -D
2364 ? Ss 0:00 /usr/sbin/smbd -D
2373 ? S 0:00 /usr/sbin/smbd -D
2377 ? Ss 0:00 /usr/sbin/sshd
2380 ? S<s 0:00 /usr/sbin/thttpd -C /etc/thttpd.conf
2382 ? S<s 0:00 /usr/sbin/thttpdbackup -C /etc/thttpd-backup.conf
2416 ? Ss 0:00 /sbin/rpc.statd
2431 ? Ss 0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g
2441 ? Ss 0:00 /usr/sbin/cron
2449 ? SLs 0:00 /usr/sbin/watchdog
2490 tty1 Ss+ 0:00 /sbin/getty 38400 tty1
2491 tty2 Ss+ 0:00 /sbin/getty 38400 tty2
2493 tty3 Ss+ 0:00 /sbin/getty 38400 tty3
2495 tty4 Ss+ 0:00 /sbin/getty 38400 tty4
2497 tty5 Ss+ 0:00 /sbin/getty 38400 tty5
2500 tty6 Ss+ 0:00 /sbin/getty 38400 tty6
2605 ? S 0:00 /USR/SBIN/CRON
2606 ? S 0:00 /USR/SBIN/CRON
2607 ? S 0:00 /USR/SBIN/CRON
2608 ? S 0:00 /USR/SBIN/CRON
2614 ? Ss 0:00 /bin/sh -c sleep 36; /srv/www/meteograph.cgi text all>/var/run/meteohub/all-sensors9.txt; /srv/www/cgi-bin/stamp.cgi cp "/var/run/meteohub/all-sensors9.txt" "/var/run/meteohub/perm/all-sensors.txt"; /srv/www/cgi-bin/stamp.cgi cp "/var/run/meteohub/all-sensors9.txt" "/data/myweb/uploads/all-sensors.txt"; /srv/www/cgi-bin/stamp.cgi mv "/var/run/meteohub/all-sensors9.txt" "/var/run/meteohub/uploads/all-sensors.txt"
2615 ? Ss 0:00 /bin/sh -c sleep 8; /srv/www/meteohtml.cgi /home/meteohub/clientrawhour.conf >/var/run/meteohub/clientrawhour.out; cp /var/run/meteohub/clientrawhour.out /data/myweb/uploads/clientrawhour.txt; cp /var/run/meteohub/clientrawhour.out /var/run/meteohub/perm/clientrawhour.txt; mv /var/run/meteohub/clientrawhour.out "/var/run/meteohub/uploads/clientrawhour.txt"
2616 ? Ss 0:00 /bin/sh -c sleep 35; [ -z "`ls /var/run/meteohub/uploads/`" ] || [ -n "`/bin/pidof /usr/bin/ncftpput`" ] || /usr/bin/ncftpput -S .tmp -R -V -DD -u "jpangelo@jpangelone.com" -p "!Ranger100" -P 21 jpangelone.com /public_html/jpangel1/weather/davis/ebox /var/run/meteohub/uploads/* 2>&1 | /usr/bin/logger
2617 ? Ss 0:00 /bin/sh -c sleep 40; /srv/www/meteograph.cgi text allxml>/var/run/meteohub/all-sensors-xml10.txt; /srv/www/cgi-bin/stamp.cgi cp "/var/run/meteohub/all-sensors-xml10.txt" "/var/run/meteohub/perm/all-sensors.xml"; /srv/www/cgi-bin/stamp.cgi cp "/var/run/meteohub/all-sensors-xml10.txt" "/data/myweb/uploads/all-sensors.xml"; /srv/www/cgi-bin/stamp.cgi mv "/var/run/meteohub/all-sensors-xml10.txt" "/var/run/meteohub/uploads/all-sensors.xml"
2619 ? S 0:00 sleep 35
2620 ? S 0:00 sleep 40
2623 ? S 0:00 sleep 36
2624 ? S 0:00 sleep 8
2640 ? Z 0:00 [watchdog] <defunct>
2641 ? S< 0:00 meteohub.cgi
2643 ? S< 0:00 /usr/sbin/thttpd -C /etc/thttpd.conf
2696 ? R< 0:00 ps ax
I think this is where I hit CONTROL-D. I don't see anything that jumps out at me. Looking like I need to rebuild the system. Guess I'll get a new CF card and have at it.
Thanks again for your help.
