Request: Log data to SQL
Posted: Wed Nov 21, 2012 9:36 am
by Cisien
I would like the option to log data to a remote SQL server instead of (or in addition to) the SD Card.
This would provide an easy way for me to query the data, and to serve a higher volume of requests.
Support for MySql at a minimum, MSSQL and others would be a plus.
Re: Request: Log data to SQL
Posted: Wed Nov 21, 2012 8:10 pm
you can build that yourself by developing a small program that makes use of the meteohub http data logger api.
http://www.meteohub.de/files/HTTP-Data- ... l-v1.2.pdf
Posted: Tue Mar 19, 2013 10:52 am
by HLucas01
I have been interested in logging Meteohub data to an external (web hosted) MySQL database for a long time and i agree with Boris that the HTTP data logger api is very powerful.
But that having said, for most of us there is a very wide gap between knowing "it is possible" and actually developing a small program.
First of all, i would expect this functionality to be part of the core Meteohub application. Meteohub's sister, Meteobridge for example has MySQL functionality built in, and also other programs such as Weather Display have MySQL functionality...
Why doesn't Meteohub?
But if it is too complex or time-consuming for Boris (he does a great job and we all do have whishes, don't we!) or there are other higher priorities, is there anyone who developed a program using the HTTP data-logger api?
Or Boris, do you have some sample code?
With a little help and some examples we users are often able to create great solutions for many problems....
Posted: Fri Mar 22, 2013 6:30 pm
by urosh
I would second that
I am not a programer, so I don't think I could help much, but allready as a backup and also that those data could be used for many things and that would also be good, as the built in card would not have to do so much => it would last longer?
I have some minor php knowledge and when I see something, I know what it does. But to do something from scratch that is a no-go for me
