Peet Bros Ultimeter 100 - Connecting to Alix1d
Posted: Tue Jan 08, 2013 12:11 am
My WMR 928 anemometer has reached its end of life.
I am thinking of buying the basic Peet Bros Ultimeter 100 and connecting both it and my existing WMR928 to my Alix 1d (with meteohub on board).
There is a bit of a problem in that both weather stations connect via RS232 and there is only one db9 male connector on the alix 1d.
I currently have the WMR928 connected via the db9 connector on the Alix 1d. So I guess I will have to unplug this to make way for the db9 connection from the ultimeter 100 as I dont see any USB connection from the Ultimeter (it has to be db9?).
I do have a USB/serial connector I used previously for connecting a WMR928 to the USB on the back of the Sheevaplug so maybe that should work for the USB on the alix 1d?
So basically I have two questions which hopefully someone can reassure me.
1) Ultimeter to Alix 1d : Connect the db9f connector (from the Ultimeter) into the db9m on the Alix 1d. Meteohub set-up drop down box identifies two baud rates, 2400 and 19200. Which option should I use?
2) WMR 928 to Alix 1d : Use the serial/usb connector I had previously to connect the WMR 928 console to one of the 2 remaining USB slots on the Alix 1d. Do I then select "USB Serial" in the drop down box on the meteohub set-up?
Will this approach work? I am a little bit nervous of the USB serial connector as it did not work very satisfactorily with the Sheeevaplug. But maybe it will be fine with the Alix 1d
