Version 1.3
Posted: Sun Apr 21, 2013 11:33 pm
Version 1.3 is out right now and summarizes some developments of the past weeks...
  • fixes a stability bug on new LOOP2 supporting Davis Vantage drivers
  • has some modules included to allow 3G modem support based on Huawei's E160 adapter (still experimental and to be formally released in one of the coming versions, profiles for "t-mobile.de" and "vodafone.de" do exist for testing purposes)
  • a new firmare release (version 1.2) is ready for download (in "getting started" section). This firmware is only needed when aiming at 3G operation.
  • added support for LOOP2 packets when using a Davis Vantage or Vue with firmware 1.90 or newer. This makes barometer readings more precise and better in sync with Vantage console.
  • fixes a problem with send email authentification
  • fxing a bug uploading average windspeed to previmeteo
  • reduce timeout for mysql connection setup to 6 seconds
  • moving static reserve LAN IP from 192.168.1.111 to 192.168.168.111 to avoid routing conficts with typical user class c networks when switching to wlan
  • removing evapotranspiration values (which did appear randomly) from solar sensor data, if not Vantage station.
  • adding a display that shows how much of internal data send buffer is currently occupied (system tab)
  • reducing memory footprint of data send process to avoid triggering oom linux mechanisms
  • doing a reboot in case of oom situations by issueing a kernel panic instead of trying to stop some applications via oom_killer.
  • added support for generation of wind direction strings in German (dedir) and English (endir) within templates.
Re: Version 1.3
Posted: Sun Apr 21, 2013 11:48 pm
by LAWx
I just rebooted my Meteobridge and received version 1.3 and it is no longer able to read my Davis Vantage Vue Pro 2 (firmware 3.12) station at all. Live data shows no data and no network traffic to any weather network or MySQL. Here is the log:
wnetd (21.04.2013 14:25:56): process started.
logger (21.04.2013 14:25:57): Free trial period will end in 3 days. When you want to use this devices beyond that period, you are welcome to use online licensing feature on "License" tab to purchase a license.
logger (21.04.2013 14:25:57): Historical data loaded (17 records).
logger (21.04.2013 14:25:57): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:25:57): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:25:58): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:25:58): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:25:58): station 0 (Vantage), syncing.
logger (21.04.2013 14:42:11): no data synchronization with station 0 (Vantage) for 900 seconds, data logger will be restarted.
logger (21.04.2013 14:42:11): disconnect station 0 (Vantage).
logger (21.04.2013 14:42:11): data logger stopped.
logger (21.04.2013 14:42:29): Historical data loaded (17 records).
logger (21.04.2013 14:42:29): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:42:30): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:42:31): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:42:31): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:42:31): station 0 (Vantage), syncing.
logger (21.04.2013 14:42:41): station 0 (Vantage), gettime request sent.
logger (21.04.2013 14:42:41): station 0 (Vantage), no Vantage time offset.
logger (21.04.2013 14:42:41): station 0 (Vantage), eeprom request sent.
logger (21.04.2013 14:42:41): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (21.04.2013 14:42:41): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (21.04.2013 14:42:41): station 0 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (21.04.2013 14:42:41): station 0 (Vantage), version request sent.
logger (21.04.2013 14:42:41): station 0 (Vantage), firmware version 3.12
logger (21.04.2013 14:42:41): station 0 (Vantage), no reading of Vantage's internal logger.
logger (21.04.2013 14:42:59): Historical data loaded (17 records).
logger (21.04.2013 14:42:59): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:43:00): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:43:00): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:43:00): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:43:00): station 0 (Vantage), syncing.
logger (21.04.2013 14:43:29): Historical data loaded (17 records).
logger (21.04.2013 14:43:29): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:43:30): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:43:30): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:43:30): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:43:30): station 0 (Vantage), syncing.
logger (21.04.2013 14:43:40): station 0 (Vantage), gettime request sent.
logger (21.04.2013 14:43:40): station 0 (Vantage), no Vantage time offset.
logger (21.04.2013 14:43:40): station 0 (Vantage), eeprom request sent.
logger (21.04.2013 14:43:41): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (21.04.2013 14:43:41): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (21.04.2013 14:43:41): station 0 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (21.04.2013 14:43:41): station 0 (Vantage), version request sent.
logger (21.04.2013 14:43:41): station 0 (Vantage), firmware version 3.12
logger (21.04.2013 14:43:41): station 0 (Vantage), no reading of Vantage's internal logger.
logger (21.04.2013 14:43:59): Historical data loaded (17 records).
logger (21.04.2013 14:43:59): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:44:00): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:44:00): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:44:00): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:44:00): station 0 (Vantage), syncing.
logger (21.04.2013 14:44:14): station 0 (Vantage), gettime request sent.
logger (21.04.2013 14:44:14): station 0 (Vantage), no Vantage time offset.
logger (21.04.2013 14:44:14): station 0 (Vantage), eeprom request sent.
logger (21.04.2013 14:44:14): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (21.04.2013 14:44:14): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (21.04.2013 14:44:14): station 0 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (21.04.2013 14:44:14): station 0 (Vantage), version request sent.
logger (21.04.2013 14:44:14): station 0 (Vantage), firmware version 3.12
logger (21.04.2013 14:44:14): station 0 (Vantage), no reading of Vantage's internal logger.
logger (21.04.2013 14:44:17): parent process received termination signal (15).
logger (21.04.2013 14:44:17): child process received termination signal (15).
logger (21.04.2013 14:44:19): disconnect station 0 (Vantage).
logger (21.04.2013 14:44:19): data logger stopped.
logger (21.04.2013 14:44:19): Free trial period will end in 3 days. When you want to use this devices beyond that period, you are welcome to use online licensing feature on "License" tab to purchase a license.
logger (21.04.2013 14:44:19): Historical data loaded (17 records).
logger (21.04.2013 14:44:19): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:44:20): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:44:21): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:44:21): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:44:22): station 0 (Vantage), syncing.
logger (21.04.2013 14:44:35): station 0 (Vantage), gettime request sent.
logger (21.04.2013 14:44:35): station 0 (Vantage), no Vantage time offset.
logger (21.04.2013 14:44:35): station 0 (Vantage), eeprom request sent.
logger (21.04.2013 14:44:35): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (21.04.2013 14:44:35): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (21.04.2013 14:44:35): station 0 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (21.04.2013 14:44:35): station 0 (Vantage), version request sent.
logger (21.04.2013 14:44:35): station 0 (Vantage), firmware version 3.12
logger (21.04.2013 14:44:35): station 0 (Vantage), no reading of Vantage's internal logger.
logger (21.04.2013 14:44:49): Historical data loaded (17 records).
logger (21.04.2013 14:44:49): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:44:50): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:44:50): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:44:50): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:44:50): station 0 (Vantage), syncing.
logger (21.04.2013 14:45:00): station 0 (Vantage), gettime request sent.
logger (21.04.2013 14:45:00): station 0 (Vantage), no Vantage time offset.
logger (21.04.2013 14:45:00): station 0 (Vantage), eeprom request sent.
logger (21.04.2013 14:45:00): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (21.04.2013 14:45:00): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (21.04.2013 14:45:00): station 0 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (21.04.2013 14:45:00): station 0 (Vantage), version request sent.
logger (21.04.2013 14:45:00): station 0 (Vantage), firmware version 3.12
logger (21.04.2013 14:45:00): station 0 (Vantage), no reading of Vantage's internal logger.
logger (21.04.2013 14:45:19): Historical data loaded (17 records).
logger (21.04.2013 14:45:19): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:45:20): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:45:20): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:45:20): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:45:20): station 0 (Vantage), syncing.
logger (21.04.2013 14:45:30): station 0 (Vantage), gettime request sent.
logger (21.04.2013 14:45:30): station 0 (Vantage), no Vantage time offset.
logger (21.04.2013 14:45:30): station 0 (Vantage), eeprom request sent.
logger (21.04.2013 14:45:31): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (21.04.2013 14:45:31): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (21.04.2013 14:45:31): station 0 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (21.04.2013 14:45:31): station 0 (Vantage), version request sent.
logger (21.04.2013 14:45:31): station 0 (Vantage), firmware version 3.12
logger (21.04.2013 14:45:31): station 0 (Vantage), no reading of Vantage's internal logger.
logger (21.04.2013 14:45:49): Historical data loaded (17 records).
logger (21.04.2013 14:45:49): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:45:50): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:45:50): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:45:50): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:45:50): station 0 (Vantage), syncing.
logger (21.04.2013 14:46:01): station 0 (Vantage), gettime request sent.
logger (21.04.2013 14:46:01): station 0 (Vantage), no Vantage time offset.
logger (21.04.2013 14:46:01): station 0 (Vantage), eeprom request sent.
logger (21.04.2013 14:46:01): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (21.04.2013 14:46:01): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (21.04.2013 14:46:01): station 0 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (21.04.2013 14:46:01): station 0 (Vantage), version request sent.
logger (21.04.2013 14:46:01): station 0 (Vantage), firmware version 3.12
logger (21.04.2013 14:46:01): station 0 (Vantage), no reading of Vantage's internal logger.
logger (21.04.2013 14:46:19): Historical data loaded (17 records).
logger (21.04.2013 14:46:19): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:46:20): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:46:20): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:46:20): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:46:20): station 0 (Vantage), syncing.
logger (21.04.2013 14:46:30): station 0 (Vantage), gettime request sent.
logger (21.04.2013 14:46:30): station 0 (Vantage), no Vantage time offset.
logger (21.04.2013 14:46:30): station 0 (Vantage), eeprom request sent.
logger (21.04.2013 14:46:31): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (21.04.2013 14:46:31): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (21.04.2013 14:46:31): station 0 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (21.04.2013 14:46:31): station 0 (Vantage), version request sent.
logger (21.04.2013 14:46:31): station 0 (Vantage), firmware version 3.12
logger (21.04.2013 14:46:31): station 0 (Vantage), no reading of Vantage's internal logger.
logger (21.04.2013 14:46:49): Historical data loaded (17 records).
logger (21.04.2013 14:46:49): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:46:50): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:46:50): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:46:50): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:46:50): station 0 (Vantage), syncing.
logger (21.04.2013 14:47:00): station 0 (Vantage), gettime request sent.
logger (21.04.2013 14:47:00): station 0 (Vantage), no Vantage time offset.
logger (21.04.2013 14:47:00): station 0 (Vantage), eeprom request sent.
logger (21.04.2013 14:47:01): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (21.04.2013 14:47:01): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (21.04.2013 14:47:01): station 0 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (21.04.2013 14:47:01): station 0 (Vantage), version request sent.
logger (21.04.2013 14:47:01): station 0 (Vantage), firmware version 3.12
logger (21.04.2013 14:47:01): station 0 (Vantage), no reading of Vantage's internal logger.
logger (21.04.2013 14:47:19): Historical data loaded (17 records).
logger (21.04.2013 14:47:19): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:47:20): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:47:20): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:47:20): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:47:20): station 0 (Vantage), syncing.
logger (21.04.2013 14:47:30): station 0 (Vantage), gettime request sent.
logger (21.04.2013 14:47:30): station 0 (Vantage), no Vantage time offset.
logger (21.04.2013 14:47:30): station 0 (Vantage), eeprom request sent.
logger (21.04.2013 14:47:31): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (21.04.2013 14:47:31): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (21.04.2013 14:47:31): station 0 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (21.04.2013 14:47:31): station 0 (Vantage), version request sent.
logger (21.04.2013 14:47:31): station 0 (Vantage), firmware version 3.12
logger (21.04.2013 14:47:31): station 0 (Vantage), no reading of Vantage's internal logger.
logger (21.04.2013 14:47:49): Historical data loaded (17 records).
logger (21.04.2013 14:47:49): data logger (version 4.9u, build 1658) started.
logger (21.04.2013 14:47:51): connect station 0 (Vantage via USB serial).
logger (21.04.2013 14:47:52): station 0 (Vantage), wakeup sent.
logger (21.04.2013 14:47:52): station 0 (Vantage), internal logger activated.
logger (21.04.2013 14:47:52): station 0 (Vantage), syncing.
Re: Version 1.3
Posted: Sun Apr 21, 2013 11:53 pm
by LAWx
It is sending the temperature and humidity data to Weather Underground even though it's reporting that it can't read the data, but it's not sending wind speed, pressure, solar radiation, UV, rain, or any other data. It's not sending any data to any of the other weather networks at all.
Re: Version 1.3
Posted: Mon Apr 22, 2013 12:15 am
I did revert for non 1.2 firmwares back to the previous release.
Doing a reboot does bring old release back to life.
@LAWx: Could you please tell me the MAC of your Meteobridge? I would like to inspect
the reason of your problems. I tested again with my Vantage Vue and it works flawlessly.
Re: Version 1.3
Posted: Mon Apr 22, 2013 3:02 am
Problem was "Open Weather Map" related and is fixed now.
Re: Version 1.3
Posted: Mon Apr 22, 2013 5:19 am
by LAWx
Thank you for the rapid support and resolution.
