				ALIX3D2 - LEDs don't blink
				Posted: Thu Oct 03, 2013 11:37 am
				by METEOshop
				Question for all users with ALIX3D2 and meteohub 4.9v. Do your Alix signalize after start its IP address by 3 LED's blinking? My doesn't do that, only LAN port blinks sometimes as data flow in and out. Is this signalization function still available? Any help in this topic appreciated.
				Re: ALIX3D2 - LEDs don't blink
				Posted: Mon Oct 07, 2013 11:56 am
				by xor
				fix /usr/sbin/alixed to /usr/sbin/alixled
				Posted: Wed Oct 30, 2013 6:33 pm
				by METEOshop
				Thanks a lot XOR.
				Posted: Sat Jan 18, 2014 4:45 pm
				by Steffi
				Hello. I have the same problem. The LED does not blink. What can I do now, so I can access on the client? Request for detailed explanation, because I do not understand the above with this code. Thx
				Posted: Sun Jan 19, 2014 8:51 pm
				by xor
				Hi, you need to change the file name /usr/sbin/alixed at /usr/sbin /alixled.
for example, "cp /usr/sbin/alixed /usr/sbin/alixled" you should be root
