Vantage Vue fails to get data after a while **solved**
Posted: Tue Nov 26, 2013 4:23 pm
by SandAndSail
Hello. I have read that MeteoBridge does not work with USB 1.x devices. I have also read that the newer Davis logger is 2.0. It was worth a try, so I connected mine direct to the bridge and it worked. But it fails to get data from the logger after a while (maybe 1/2 to 1 hour). Reboot and it works again. On reboot, the log reads the same each time, but it's working.
Seems to me that if it's a 2.0 problem, there would be a failure from the start. Can someone please advise if this sort of failure is reminiscent of a 1.x-2.0 problem or if it's something different? Thank you.
wnetd (26.11.2013 05:39:07): process started.
logger (26.11.2013 05:39:10): Historical data loaded (15 records).
logger (26.11.2013 05:39:10): data logger (version 4.9v, build 2927) started.
logger (26.11.2013 05:39:11): connect station 0 (Vantage via USB serial).
logger (26.11.2013 05:39:12): station 0 (Vantage), wakeup sent.
logger (26.11.2013 05:39:12): station 0 (Vantage), internal logger activated.
logger (26.11.2013 05:39:12): station 0 (Vantage), syncing.
logger (26.11.2013 05:40:40): station 0 (Vantage), gettime request sent.
logger (26.11.2013 05:40:40): station 0 (Vantage), no Vantage time offset.
logger (26.11.2013 05:40:40): station 0 (Vantage), eeprom request sent.
logger (26.11.2013 05:40:40): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (26.11.2013 05:40:40): station 0 (Vantage), transmitter 3 active as station type (#0) "ISS".
logger (26.11.2013 05:40:40): station 0 (Vantage), firmware version request sent.
logger (26.11.2013 05:40:56): station 0 (Vantage), no firmware version returned.
logger (26.11.2013 05:40:56): station 0 (Vantage), no reading of Vantage's internal logger.
Re: Vantage Vue fails to get data after a while
Posted: Tue Nov 26, 2013 8:30 pm
you ALWAYS need the USB 2.0 hub.
Posted: Wed Nov 27, 2013 6:40 am
by SandAndSail
Well, damn. Right you are. Thank you.
Back to my log file, is the failure to get the firmware version and internal logger normal? I would presume that if it was normal, the device wouldn't show it as an error of sorts.
Posted: Thu Nov 28, 2013 2:03 am
"no reading of Vantage's internal logger" is not an error, it just reminds that historical data logged inside the Davis unit is not loaded into Meteobridge when starting operation.
