DC01 and VP2+ solar data error provided by meteohub
Posted: Fri Feb 14, 2014 6:11 pm
one my friend has DC01 + VP2. He claim, that after few hours of normal behaviour solar sensor in WDL is showing just -% instead of value% - see http://tomas.tbt.cz/josefov/ alternative http://tomas.tbt.cz/josefov/all-sensors.txt
He send me DC01 and I tested it with our VP2 several days and didn't notice such behaviour (26.01. - 27.01. from log below). However after return back to friend, it started again to do such strange behaviour.
On sensor page is value ok, but problem is in WDL and also in parameter in file all-sensors.txt
I noticed that all-sensors.txt file doesn't have value for parameter: actual_sol0_radiation_rel
when I connected meteohub to our station, this parameter was generated well.
There is just one difference between our VP2 and customer's, our firmware in station is 1.80, customer has 1.90.
Do you have any idea what should be problem or how to solve this?
Michal
Meteohub log below:
logger (26.01.2014 19:42:36): station 0 (Vantage), no Vantage time offset.
logger (26.01.2014 19:42:36): station 0 (Vantage), eeprom request sent.
logger (26.01.2014 19:42:36): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (26.01.2014 19:42:36): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (26.01.2014 19:42:36): station 0 (Vantage), firmware version request sent.
logger (26.01.2014 19:42:36): station 0 (Vantage), firmware version 1.80
logger (26.01.2014 19:42:36): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 170 secs
logger (27.01.2014 19:40:08): parent process received termination signal (15).
logger (27.01.2014 19:40:08): child process received termination signal (15).
logger (27.01.2014 19:42:16): data logger (version 4.9v, build 1428) started.
logger (27.01.2014 19:42:17): connect station 0 (Vantage via USB serial).
logger (27.01.2014 19:42:18): station 0 (Vantage), wakeup sent.
logger (27.01.2014 19:42:18): station 0 (Vantage), internal logger activated.
logger (27.01.2014 19:42:18): station 0 (Vantage), syncing.
logger (27.01.2014 19:42:28): station 0 (Vantage), gettime request sent.
logger (27.01.2014 19:42:28): station 0 (Vantage), no Vantage time offset.
logger (27.01.2014 19:42:28): station 0 (Vantage), eeprom request sent.
logger (27.01.2014 19:42:28): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (27.01.2014 19:42:28): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (27.01.2014 19:42:28): station 0 (Vantage), firmware version request sent.
logger (27.01.2014 19:42:28): station 0 (Vantage), firmware version 1.80
logger (27.01.2014 19:42:28): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 197 secs
logger (29.01.2014 19:07:01): data logger (version 4.9v, build 1428) started.
logger (29.01.2014 19:07:02): connect station 0 (Vantage via USB serial).
logger (29.01.2014 19:07:03): station 0 (Vantage), wakeup sent.
logger (29.01.2014 19:07:03): station 0 (Vantage), internal logger activated.
logger (29.01.2014 19:07:03): station 0 (Vantage), syncing.
logger (29.01.2014 19:07:13): station 0 (Vantage), gettime request sent.
logger (29.01.2014 19:07:13): station 0 (Vantage), no Vantage time offset.
logger (29.01.2014 19:07:13): station 0 (Vantage), eeprom request sent.
logger (29.01.2014 19:07:13): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2014 19:07:13): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.01.2014 19:07:13): station 0 (Vantage), firmware version request sent.
logger (29.01.2014 19:07:13): station 0 (Vantage), firmware version 1.90
logger (29.01.2014 19:07:23): station 0 (Vantage), data gap of 1986 minutes, start reading Vantage's internal logger after 2014-01-28 10:00 (Vantage's local time).
logger (29.01.2014 19:07:23): station 0 (Vantage), internal logger provides 14 pages of data.
logger (29.01.2014 19:07:26): station 0 (Vantage), finished reading internal logger, 66 records inserted.
wmr928fulleval(29.01.2014 19:10:02): recomputation of weather data started.
logger (29.01.2014 19:23:00): data logger (version 4.9v, build 1428) started.
logger (29.01.2014 19:23:01): connect station 0 (Vantage via USB serial).
logger (29.01.2014 19:23:02): station 0 (Vantage), wakeup sent.
logger (29.01.2014 19:23:02): station 0 (Vantage), internal logger activated.
logger (29.01.2014 19:23:02): station 0 (Vantage), syncing.
logger (29.01.2014 19:23:12): station 0 (Vantage), gettime request sent.
logger (29.01.2014 19:23:12): station 0 (Vantage), no Vantage time offset.
logger (29.01.2014 19:23:12): station 0 (Vantage), eeprom request sent.
logger (29.01.2014 19:23:12): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2014 19:23:12): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.01.2014 19:23:12): station 0 (Vantage), firmware version request sent.
logger (29.01.2014 19:23:12): station 0 (Vantage), firmware version 1.90
logger (29.01.2014 19:23:12): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 439 secs
logger (29.01.2014 19:24:50): unexpected 0 bytes delivered from weather station 0 (Vantage)
logger (29.01.2014 19:24:50): station 0 (Vantage), can't set attributes of device /dev/ttyUSB0 to former values: Input/output error
logger (29.01.2014 19:24:50): disconnect station 0 (Vantage): response without data
wmr928fulleval(29.01.2014 19:25:01): recomputation of weather data started.
logger (29.01.2014 19:25:20): connect station 0 (Vantage via USB serial).
logger (29.01.2014 19:25:21): station 0 (Vantage), wakeup sent.
logger (29.01.2014 19:25:21): station 0 (Vantage), internal logger activated.
logger (29.01.2014 19:25:21): station 0 (Vantage), syncing.
logger (29.01.2014 19:25:31): station 0 (Vantage), gettime request sent.
logger (29.01.2014 19:25:31): station 0 (Vantage), no Vantage time offset.
logger (29.01.2014 19:25:31): station 0 (Vantage), eeprom request sent.
logger (29.01.2014 19:25:31): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2014 19:25:31): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.01.2014 19:25:31): station 0 (Vantage), firmware version request sent.
logger (29.01.2014 19:25:31): station 0 (Vantage), firmware version 1.90
logger (29.01.2014 19:25:31): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 72 secs
logger (29.01.2014 19:27:37): unexpected 0 bytes delivered from weather station 0 (Vantage)
logger (29.01.2014 19:27:37): station 0 (Vantage), can't set attributes of device /dev/ttyUSB0 to former values: Input/output error
logger (29.01.2014 19:27:37): disconnect station 0 (Vantage): response without data
logger (29.01.2014 19:28:07): connect station 0 (Vantage via USB serial).
logger (29.01.2014 19:28:08): station 0 (Vantage), wakeup sent.
logger (29.01.2014 19:28:08): station 0 (Vantage), internal logger activated.
logger (29.01.2014 19:28:08): station 0 (Vantage), syncing.
logger (29.01.2014 19:28:18): station 0 (Vantage), gettime request sent.
logger (29.01.2014 19:28:18): station 0 (Vantage), no Vantage time offset.
logger (29.01.2014 19:28:18): station 0 (Vantage), eeprom request sent.
logger (29.01.2014 19:28:18): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (29.01.2014 19:28:18): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (29.01.2014 19:28:18): station 0 (Vantage), firmware version request sent.
logger (29.01.2014 19:28:18): station 0 (Vantage), firmware version 1.90
logger (29.01.2014 19:28:18): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 101 secs
logger (30.01.2014 15:21:53): data logger (version 4.9v, build 1428) started.
logger (30.01.2014 15:21:54): connect station 0 (Vantage via USB serial).
logger (30.01.2014 15:21:55): station 0 (Vantage), wakeup sent.
logger (30.01.2014 15:21:55): station 0 (Vantage), internal logger activated.
logger (30.01.2014 15:21:55): station 0 (Vantage), syncing.
logger (30.01.2014 15:22:05): station 0 (Vantage), gettime request sent.
logger (30.01.2014 15:22:05): station 0 (Vantage), no Vantage time offset.
logger (30.01.2014 15:22:05): station 0 (Vantage), eeprom request sent.
logger (30.01.2014 15:22:05): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (30.01.2014 15:22:05): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (30.01.2014 15:22:05): station 0 (Vantage), firmware version request sent.
logger (30.01.2014 15:22:05): station 0 (Vantage), firmware version 1.90
logger (30.01.2014 15:22:15): station 0 (Vantage), data gap of 1190 minutes, start reading Vantage's internal logger after 2014-01-29 19:30 (Vantage's local time).
logger (30.01.2014 15:22:15): station 0 (Vantage), internal logger provides 9 pages of data.
logger (30.01.2014 15:22:16): station 0 (Vantage), finished reading internal logger, 39 records inserted.
wmr928fulleval(30.01.2014 15:25:02): recomputation of weather data started.
wmr928fulleval(30.01.2014 18:16:48): recomputation of weather data finished: 8104059 records processed in 10301 seconds (786 records per second)
logger (30.01.2014 19:40:07): parent process received termination signal (15).
logger (30.01.2014 19:40:08): child process received termination signal (15).
logger (30.01.2014 19:40:08): disconnect station 0 (Vantage): wrap-up
logger (30.01.2014 19:40:09): data logger stopped.
logger (30.01.2014 19:42:21): data logger (version 4.9v, build 1428) started.
logger (30.01.2014 19:42:22): connect station 0 (Vantage via USB serial).
logger (30.01.2014 19:42:23): station 0 (Vantage), wakeup sent.
logger (30.01.2014 19:42:23): station 0 (Vantage), internal logger activated.
logger (30.01.2014 19:42:23): station 0 (Vantage), syncing.
logger (30.01.2014 19:42:33): station 0 (Vantage), gettime request sent.
logger (30.01.2014 19:42:33): station 0 (Vantage), no Vantage time offset.
logger (30.01.2014 19:42:33): station 0 (Vantage), eeprom request sent.
logger (30.01.2014 19:42:33): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (30.01.2014 19:42:33): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (30.01.2014 19:42:33): station 0 (Vantage), firmware version request sent.
logger (30.01.2014 19:42:33): station 0 (Vantage), firmware version 1.90
logger (30.01.2014 19:42:33): station 0 (Vantage), no reading of Vantage's internal logger as data gap is less than 10 minutes: 183 secs
Michal
Meteohub log below:
