No such file or directory **solved**
Posted: Sun Mar 23, 2014 3:30 pm
by grwkak
Following directions to flash the firmware of my TP-LINK TL-MR3020. When I try to access the fwupdate.cgi page I get the "no such file or directory" error message.
I am connecting via wireless - does this require access via a cable?
Guy
Re: No such file or directory
Posted: Sun Mar 23, 2014 3:50 pm
by grwkak
Solved - rebooted meteobridge and was able to access.
Re: No such file or directory - solved
Posted: Sun Mar 23, 2014 8:55 pm
yes, it needs a new file to be downloaded, which is part of the newly released application stack.
Re: No such file or directory **solved**
Posted: Mon Mar 24, 2014 1:32 am
by grwkak
Looks like the WMR100 still needs a USB hub?
Guy
Posted: Tue Mar 25, 2014 2:49 pm
by Ed_Heaton
I purchased my meteobridge (TL-MR3020) from Ambient Weather and my unit has an expert mode that allows me to flash the unit. Should I use this method instead of the one noted? Also, my unit is working correctly should I upgrade?
Thanks!!!
Ed
Posted: Tue Mar 25, 2014 5:41 pm
I wouldn't recommend to update the firmware, when you already have a package from ambient that includes all you need.
Beside replacement of the USB hub (for non USB HID) stations you gain nothing, but face the risk of having a bad flash.
If you decide to take the risk, please use the method as explained in the announcement. This makes sure some
services are shut down in advance, which can interfere badly when doing the flash.
Posted: Tue Mar 25, 2014 5:45 pm
grwkak wrote:Looks like the WMR100 still needs a USB hub?
I checked with my WMR100 and it still needs the hub. Including UHCI and/or OHCI
kernel drivers into the build also didn't fix that. So for the moment it just seems to
cure USB serial connected stations like Vantage, WMR928, WH2300 to name the
most well-known.
Posted: Tue Mar 25, 2014 6:17 pm
by Ed_Heaton
Thank you for the reply and I guess I just stick with what's working!!! Thanks again for the advice!
Posted: Thu Mar 27, 2014 10:46 am
by BoMu
My WH 3080 still needs a USB-Hub
