Export WD Data Log Problem
Posted: Tue Apr 29, 2014 11:30 pm
I have data going back until October on my SheevaPlug Meteohub device. I am trying to use the "WD Data Export" function to re-create log files for Weather Display. When I use the function, I match up each sensor to the applicable piece of data, and then click "Generate". I find the log file in /data/export - but when I view the log, it is filled with "-999" for every single item of data. I know the data exists, because I can use it to generate graphs for those periods. Whats the issue with this function? I've tried every month I have data for, with the same results.
Also -- is it possible to incorporate the Solar/UV data in the mmyyyyvantagelog.txt file that WD uses with this function?
