System Log error message!
Posted: Thu Jul 10, 2014 6:01 pm
by ajwhall
Hi to the Forum,
Can any one give me any pointers as to what is causing the following message:
wdcut (10.07.2014 17:47:03): Error file open /data/export/wd_export.csv: No such file or directory
Would be most grateful for any help,
Best Regards,
Andrew.
Re: System Log error message!
Posted: Sun Jul 20, 2014 9:39 pm
by joachimF
Bonsoir Andrew,
did you find a solution for the error log message?
I have the same problem.
Posted: Tue Jul 22, 2014 10:26 am
by ajwhall
Hello Joachim!
I have found no solution to this problem but at the moment it has stopped showing in the log!
May be Boris could possibly shed some light on this problem for us?
Best Regards,
Andrew.
Posted: Tue Jul 22, 2014 8:53 pm
by ajwhall
Just to update, I still have the problem!
It appears that I skipped though the logs a bit too quick before seeing the error messages again!!!
I also did a restart today without any change.
Regards,
Andrew.
Re: System Log error message! [solved]
Posted: Wed Jul 23, 2014 5:12 pm
by joachimF
I made 2 zero byte files with the following commands :
cat > /data/export/EXP01_00.csv
cat > /data/export/wd_export.csv
The error message 'find no files' does not appear.
Posted: Fri Jul 25, 2014 10:30 am
by ajwhall
Hi Joachim et al,
This seems to have done the trick!
Many thanks,
Andrew.
Posted: Mon Nov 10, 2014 8:43 pm
by eric738
Good Evening
i have too this error message but i dont understand your soluce, can you explain again please ?
thank in advance
Eric
