Datalogger restart
Posted: Mon Sep 15, 2014 8:53 am
by assenzuid
I'm using the lastets build version, loaded yesterday, but I notice that this morning at 8:00 hours the datalogger is restarted for some reason.
I can't see any errors in de log.
Re: Datalogger restart
Posted: Mon Sep 15, 2014 3:59 pm
by assenzuid
This behavior is since the last update, looks that it now every 4 hours occuers.
See systemlog
logger (15.09.2014 08:00:03): data logger (version 5.0, build 2619) started.
logger (15.09.2014 08:00:05): connect station 0 (Vantage via USB serial).
logger (15.09.2014 08:00:06): station 0 (Vantage), wakeup sent.
logger (15.09.2014 08:00:06): station 0 (Vantage), internal logger activated.
logger (15.09.2014 08:00:06): station 0 (Vantage), syncing.
logger (15.09.2014 08:00:16): station 0 (Vantage), gettime request sent.
logger (15.09.2014 08:00:16): station 0 (Vantage), no Vantage time offset.
logger (15.09.2014 08:00:16): station 0 (Vantage), eeprom request sent.
logger (15.09.2014 08:00:16): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (15.09.2014 08:00:16): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (15.09.2014 08:00:16): station 0 (Vantage), transmitter 2 active as station type (#4) "Wind".
logger (15.09.2014 08:00:16): station 0 (Vantage), transmitter 3 active as station type (#8) "Leaf/Soil".
logger (15.09.2014 08:00:16): station 0 (Vantage), firmware version request sent.
logger (15.09.2014 08:00:16): station 0 (Vantage), firmware version 3.15
logger (15.09.2014 08:00:16): station 0 (Vantage), no reading of Vantage's internal logger.
logger (15.09.2014 12:01:04): Historical data loaded (22 records).
logger (15.09.2014 12:01:04): data logger (version 5.0, build 2619) started.
logger (15.09.2014 12:01:05): connect station 0 (Vantage via USB serial).
logger (15.09.2014 12:01:06): station 0 (Vantage), wakeup sent.
logger (15.09.2014 12:01:06): station 0 (Vantage), internal logger activated.
logger (15.09.2014 12:01:06): station 0 (Vantage), syncing.
logger (15.09.2014 12:01:16): station 0 (Vantage), gettime request sent.
logger (15.09.2014 12:01:16): station 0 (Vantage), no Vantage time offset.
logger (15.09.2014 12:01:16): station 0 (Vantage), eeprom request sent.
logger (15.09.2014 12:01:16): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (15.09.2014 12:01:16): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (15.09.2014 12:01:16): station 0 (Vantage), transmitter 2 active as station type (#4) "Wind".
logger (15.09.2014 12:01:16): station 0 (Vantage), transmitter 3 active as station type (#8) "Leaf/Soil".
logger (15.09.2014 12:01:16): station 0 (Vantage), firmware version request sent.
logger (15.09.2014 12:01:16): station 0 (Vantage), firmware version 3.15
logger (15.09.2014 12:01:16): station 0 (Vantage), no reading of Vantage's internal logger.
logger (15.09.2014 15:20:48): Historical data loaded (22 records).
logger (15.09.2014 15:20:48): data logger (version 5.0, build 2619) started.
logger (15.09.2014 15:20:50): connect station 0 (Vantage via USB serial).
logger (15.09.2014 15:20:50): station 0 (Vantage), wakeup sent.
logger (15.09.2014 15:20:50): station 0 (Vantage), internal logger activated.
logger (15.09.2014 15:20:50): station 0 (Vantage), syncing.
logger (15.09.2014 15:21:00): station 0 (Vantage), gettime request sent.
logger (15.09.2014 15:21:00): station 0 (Vantage), no Vantage time offset.
logger (15.09.2014 15:21:00): station 0 (Vantage), eeprom request sent.
logger (15.09.2014 15:21:00): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (15.09.2014 15:21:00): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (15.09.2014 15:21:00): station 0 (Vantage), transmitter 2 active as station type (#4) "Wind".
logger (15.09.2014 15:21:00): station 0 (Vantage), transmitter 3 active as station type (#8) "Leaf/Soil".
logger (15.09.2014 15:21:00): station 0 (Vantage), firmware version request sent.
logger (15.09.2014 15:21:00): station 0 (Vantage), firmware version 3.15
logger (15.09.2014 15:21:00): station 0 (Vantage), no reading of Vantage's internal logger.
Yesterday morning I added the following alarm item as test:
One time alarm - email
raise: [th10temp-act=c.1:0] < 15 ) && ( ( [hh] != 0 ) || ( [mm] != 0 )
clear: [th10temp-act=c.1:0] > 15 ) || ( ( [hh] = 0 ) && ( [mm] = 0 )
Subj # Body: blabla
To-Addr:
email@email.com
Yesterday evening (after 22:00 hours) I rebooted the system to install the latest build.
Weatherstation Assen Zuid-West
