WS888 additional sensors not in push services **solved**
Posted: Mon Sep 22, 2014 8:29 pm
by Bas
I've got the Conrad WS888 hooked up to a TP-LINK 703N and it seems to work.
The WS888 is configured with the maximum amount of external sensors and they all show up in MeteoBridge live data ( see below)
Live Data
Sensor
Indoor 19 sec 29.1°C 44% 1020.5hPa (1017.0hPa) 84.4°F 44% 30.14inHg (30.03inHg)
Outdoor 19 sec 16.9°C 60% (dew 9.1°C, heat 16.9°C) 62.4°F 60% (dew 48.4°F, heat 62.4°F)
Outdoor #1 19 sec 21.0°C 53% (dew 11.1°C, heat 21.0°C) 69.8°F 53% (dew 52.0°F, heat 69.8°F)
Outdoor #2 19 sec 21.0°C 53% (dew 11.1°C, heat 21.0°C) 69.8°F 53% (dew 52.0°F, heat 69.8°F)
Outdoor #3 19 sec 21.1°C 55% (dew 11.7°C, heat 21.1°C) 70.0°F 55% (dew 53.1°F, heat 70.0°F)
Outdoor #4 19 sec 20.8°C 52% (dew 10.6°C, heat 20.8°C) 69.4°F 52% (dew 51.1°F, heat 69.4°F)
Outdoor #5 19 sec 21.0°C 53% (dew 11.1°C, heat 21.0°C) 69.8°F 53% (dew 52.0°F, heat 69.8°F)
Outdoor #6 19 sec 21.3°C 53% (dew 11.3°C, heat 21.3°C) 70.3°F 53% (dew 52.3°F, heat 70.3°F)
Outdoor #7 19 sec 16.5°C 59% (dew 8.5°C, heat 16.5°C) 61.7°F 59% (dew 47.3°F, heat 61.7°F)
Wind 19 sec 0.0m/s (avg 0.0m/s) 110° ESE 0.0mph (avg 0.0mph) 110° ESE
Rain 19 sec rate 0.0mm/h rate 0.00in/h
unknown 19 sec 0.00 0.00
Outdoor T #8 19 sec 15.5°C 59.9°F
I tried to export the sensor data to email, but that is only working with the main sensors of the weatherstation. (only these show up in the historical data)
[th0temp-act] will export to 29.1, but [th1temp-act] just puts [th1temp-act] as text in the email. (I expected the Outdoor #1 sensor as th1temp in the email) It doesn't recognise the additional sensors to use as tags
What can I do with the 'unknown' sensor? I know it represents the build in sun hours sensor of the basic outdoor sensor.
Is there a way to get the additional sensors to work in the push services?
Kind regards,
Bas
Re: WS888 additional sensors not in push services
Posted: Tue Sep 23, 2014 1:28 am
A reboot should fix this.
Posted: Tue Sep 23, 2014 8:32 pm
by Bas
Unfortunately the reboot doesn't work.
I completely recycled the power of the router and still the same problem. I get 15.7 [th1temp-act] [th2temp-act] [th3temp-act] as the result. The extra sensors are not recognized.
I looked at /home/meteohub/logger.conf and I can see something has changed since yesterday. More sensors are added.
Yesterday I tried to add them myself, but after a reboot the changed file was replaced by the original one.
Is there a possibility to configure the extra sensors myself? ID#1 to ID#7 = TH, ID#8 = T
What to do with the 'unknown' sensor which is sun hours?
Kind regards,
Bas
Posted: Tue Sep 23, 2014 10:15 pm
When sensors are listed in the historical data section, then they should be usable via template variables.
Meteobridge does not support giving sensors individual IDs. The primary sensors are used for
weather network reporting. You can use additional sensors in your own templates etc only.
When you want me to have a look at your settings, please follow instructions given here:
viewtopic.php?f=57&t=9885
