Stop posting to twitter
Posted: Thu Sep 25, 2014 9:29 pm
by anubirus
i have meteobridge since may and I was posting to twitter since day 1 with no problem until this morning when the post began to fail. I post the data every hour to twitter. I get the duplicate messages most of the time and one time i get the other messages. i dont make any change to the formula. I change the time from one hours to 30 minutes and work so i set up to one our again and after 2 hours stop working. here are pics of the errors
Image Image
Re: Stop posting to twitter
Posted: Thu Sep 25, 2014 10:06 pm
First pic is about twitter not accepting two identical tweets. That is normal behavior, don't worry.
Second message tells that a bad character is in the tweet.
Can you please share the message definition of the tweet,
so that I can understand where this character does come from?
Posted: Thu Sep 25, 2014 10:18 pm
by anubirus
Thanks for the help
Im using MB to post to twitter for 4 months and this never happen before.
What can cause the duplicate message? MB stop posting to twitter for 3 hours.
I not sure what you mean with definition of the messages but here is the last tweet posted:
Hora 01:03PM Temperatura 86.5°F Viento 7.2mph ENE Rafagas 8.3mph Precipitacion 0.00in Presión 29.73inHg #prwx #tiempo #clima #weather
and here is the formula i use:
Hora [HH]:[mm][APM] Temperatura [th0temp-act=F.1:--]°F Viento [wind0wind-act=mph.1:--]mph [wind0dir-act=endir:---] Rafagas [wind0wind-max10=mph.1:--]mph Precipitacion [rain0total-sum1h=in.2:---]in Presión [thb0press-act=inHg.2----]inHg #prwx #tiempo #clima #weather
Posted: Thu Sep 25, 2014 10:23 pm
I guess the "Presión" does kill it.
Posted: Thu Sep 25, 2014 11:00 pm
by anubirus
erase almost all code except for the hour and temperature. still not working. alsol reboot the MB.
Posted: Thu Sep 25, 2014 11:18 pm
try "°" instead of °
Posted: Fri Sep 26, 2014 3:22 pm
by anubirus
i disconnect everything for a couple of hours. put all back together before goes to bed and today everything is working like always. The problem looks like fix himself. Hope no more problem. Thanks for your help
