RainWise MkII partial data **solved**
Posted: Sun Sep 28, 2014 3:38 am
by debrogle
Temperature, wind and rainfall are OK but barometric pressure is returning a "Bad thb0(0) sensor data, "sea level pressure x10" (-999) out of range [4000:12000]"
The MkIII has worked previously with meteohub and iConnect
A powered USB hub is in line with the serial output.
Pressure correction is set to 0
The live data is as follows and has a very peculiar date stamp which is probably a clue:
19700101000000 thb0 186996798.1 100 184761660.9 17007416.4 195298109.0 1819239275
20140928000821 th0 15.0 10 -16.4
20140928000821 wind0 292 0.0 0.0 15.0
20140928000821 rain0 0.0 0.0 0.0
Any help would be appreciated -- thanks in advance !
Re: RainWise MkII partial data
Posted: Sun Sep 28, 2014 3:32 pm
Are the problems related to Meteobridge or a Meteohub with new hardware?
As you mention it has been working ok on Meteohub/iConnect, I would be interested to understand what has changed.
Posted: Sun Sep 28, 2014 3:48 pm
by debrogle
My apologies -- the meteohub was used on a NSLU2 and an iConnect. This time we are using a TP-Link TL-MR3020 unit which was recently purchased and set up
I can get you the MAC address if that would help
Posted: Sun Sep 28, 2014 3:51 pm
yes, please do.
Posted: Mon Sep 29, 2014 4:10 am
by debrogle
MAC sent to info@ -- is that the correct address ?
Re: RainWise MkII partial data ***Solved***
Posted: Mon Sep 29, 2014 4:19 am
by debrogle
Voila again -- many thanks :D
