Connection issue with Vantage Pro 2
Posted: Wed Oct 29, 2014 11:02 am
I started the discussion in another thread (viewtopic.php?f=56&t=9981) but it marked as solved so I start my own here.
I have this kind of log on the Sytem tab:
Admin said that is was because there was no USB HUB between the datalogger and the bridge. So I purchased one and installed it.
Result: we still have that error and sometimes we lose live data.
Is there anything I can do?
Thank you.
wnetd (17.10.2014 14:02:52): process started.
test5m (17.10.2014 14:02:55): logger stalled, will be restarted now
logger (17.10.2014 14:02:56): Historical data loaded (18 records).
logger (17.10.2014 14:02:56): data logger (version 5.0, build 5034) started.
logger (17.10.2014 14:02:56): connect station 0 (Vantage via USB serial).
logger (17.10.2014 14:02:57): station 0 (Vantage), wakeup sent.
logger (17.10.2014 14:02:58): station 0 (Vantage), internal logger activated.
logger (17.10.2014 14:02:58): station 0 (Vantage), syncing.
logger (17.10.2014 14:03:08): station 0 (Vantage), gettime request sent.
logger (17.10.2014 14:03:08): station 0 (Vantage), no Vantage time offset.
logger (17.10.2014 14:03:08): station 0 (Vantage), eeprom request sent.
logger (17.10.2014 14:03:08): station 0 (Vantage), rain collector size 0.2 mm per tick.
logger (17.10.2014 14:03:08): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (17.10.2014 14:03:08): station 0 (Vantage), transmitter 4 active as station type (#4) "Wind".
logger (17.10.2014 14:03:08): station 0 (Vantage), firmware version request sent.
logger (17.10.2014 14:03:08): station 0 (Vantage), firmware version 3.15
logger (17.10.2014 14:03:08): station 0 (Vantage), no reading of Vantage's internal logger.
logger (19.10.2014 09:09:26): child process received timeout signal (14).
logger (19.10.2014 09:10:12): data logger stopped.
logger (19.10.2014 09:10:12): Historical data loaded (18 records).
logger (19.10.2014 09:10:12): data logger (version 5.0, build 5034) started.
logger (19.10.2014 09:10:22): station 0 (Vantage), can't open device /dev/ttyMH: Input/output error
logger (19.10.2014 09:10:52): station 0 (Vantage), can't open device /dev/ttyMH: Input/output error
logger (19.10.2014 09:11:22): station 0 (Vantage), can't open device /dev/ttyMH: Input/output error
logger (19.10.2014 09:11:52): station 0 (Vantage), can't open device /dev/ttyMH: Input/output error
logger (19.10.2014 09:12:22): station 0 (Vantage), can't open device /dev/ttyMH: Input/output error
logger (19.10.2014 09:12:52): station 0 (Vantage), can't open device /dev/ttyMH: Input/output error
logger (19.10.2014 09:13:22): station 0 (Vantage), can't open device /dev/ttyMH: Input/output error
logger (19.10.2014 09:13:52): station 0 (Vantage), can't open device /dev/ttyMH: Input/output error
logger (19.10.2014 09:14:22): station 0 (Vantage), can't open device /dev/ttyMH: Input/output error
logger (19.10.2014 09:14:52): station 0 (Vantage), can't open device /dev/ttyMH: Input/output error
logger (19.10.2014 09:20:52): child process received timeout signal (14).
logger (19.10.2014 09:20:53): data logger stopped.
logger (19.10.2014 09:20:53): Historical data loaded (18 records).
logger (19.10.2014 09:20:53): data logger (version 5.0, build 5034) started.Result: we still have that error and sometimes we lose live data.
Thank you.
