For about 6 months now, I have an issue with WDL 6.05 & WDL 6.06 regarding the
annual rainfall graph display.
Actually, the annual quantity displayed is correct (which dispels any data retrieval)
but, the annual rainfall graph displays inaccurate informations (different total, missing months...).
My father owns the exact same system as mine and doesn't encounter any issues.
Here's my website address : http://mameteopartout.free.fr/
And here's my father's : http://mameteomirande.free.fr/
Have you ever had this kind of problems ? If so, do you have any solution in mind ?
Thanks in advance for you help in solving this issue.
Annual rainfall data compilation error
Hugwarrior
- Fresh Boarder
- YJB
Re: Annual rainfall data compilation error
I'm wondering did you change the name of the sensor at some point in time e.g. rain0, then rain1, and then rain0 again? This could be a problem, as the clientraw will only use a single sensor. Since your totals are right, this is probably not the case, but one never knows.
Beyond that, WDL is using Clientrawdaily.txt (fields 187 - 198). These values are calculated from aggregated data (seqmonth1_rain0_total_mm), so your best bet would be to run a recompute (maintenance tab), and see if that helps.
Ysbrand
Ysbrand
Hugwarrior
- Fresh Boarder
Hi again,
Thanks for your fast answer.
Actually, I never changed the rain sensor's name, it's always been Rain 0.
And, as I do restart my server every sunday @ 10 PM, my datas are
recomputed automatically once a week.
Any other idea ?
Many thanks for your help.
Any other idea ?
- YJB
Are you sure about that, a scheduled reboot will not force a recomputation as far as I know. Can you please check your logs for messages that confirm the recomputation?Hugwarrior wrote: as I do restart my server every sunday @ 10 PM, my datas are
Hugwarrior
- Fresh Boarder
I checked the reboot function, and it seems that it recomputes automatically all the datas. Anyway,
after a manual recompute process, it appears that the problem was still live.
But, yesterday night, when my server restarted as scheduled every sunday, I found out that my storage USB
drives was failing. So, I reinstalled the complete system on a new one, and the problem is solved.
Thanks for your help,
