NOAA support
Requests for future functionality
cirieh
NOAA support
Post by cirieh »
noaamo daily etc.
Re:NOAA support
could you please explain a bit more detailed what you are looking for or asking?
Sorry, I don't understand.
cirieh
Re:NOAA support
Post by cirieh »
a creation of a NOAA
CLIMATE REPORT (MONTHLY/YEARLY) like this(this was build with VWS):
                  MONTHLY CLIMATOLOGICAL SUMMARY FOR 5/2008
                                        HEAT  COOL
     MEAN                               DEG   DEG       WIND SPEED       DOM MEAN  MEAN
DAY  TEMP  HIGH   TIME     LOW   TIME   DAYS  DAYS RAIN AVG  HI  TIME    DIR BAROM HUM
1
2
3    21.6  25.1    15:38  17.4    22:14   25    0  0.00   0   0    10:06   N1016.68   42
4    19.9  25.1    14:41  14.9     5:04   45    0  0.00   0   0     0:00   N1016.13   38
5    19.7  24.9    15:23  14.7     5:52   45    0  0.00   0   0     0:00   N1017.41   27
6    18.4  23.1    11:22  15.6     6:14   47    0  0.00   0   0     0:00   N1016.05   58
7    18.5  23.9    14:58  15.5     5:41   46    0  0.00   0   0     0:00   N1015.00   77
8    18.9  23.7    14:02  14.2     5:08   46    0  0.00   0   5    13:02 ENE1016.23   48
9    18.2  22.9    15:40  13.8     5:03   47    0  0.00   0   5    20:43 ENE1014.13   60
10   18.2  20.8    14:29  16.5     5:18   45    0  0.00   0   6     8:23 ENE1010.32   72
11    0.0  20.1    21:20  20.1    21:20    0    0  0.00   0   0    21:20 ---  0.00    0
12
13
14
15
16   19.9  20.3    21:35  19.4    23:51    5    0  0.00   0   0    21:20   N1014.42   92
17   19.9  23.6    14:50  17.9     6:20   45    0  0.00   0   0     0:00   N1012.22   90
18    0.0  23.9    12:42  23.9    12:42    0    0  0.00   0   0    12:42 ---  0.00    0
19
20
21    0.0  17.7     2:13  17.7     2:13    0    0  0.00   0   0     2:13 ---  0.00    0
22    0.0  17.7     2:13  17.7     2:13    0    0  0.00   0   0     2:13 ---  0.00    0
TOT  19.1  25.1   3/5/08  13.8   9/5/08  396    0  4.00   0   6  10/5/08 ENE1014.11   62
HEAT BASE: 65.0
COOL BASE: 65.0
                  YEARLY CLIMATOLOGICAL SUMMARY FOR 2008
                                        HEAT  COOL
MON  TEMP  HIGH   DATE     LOW   DATE   DAYS  DAYS RAIN AVG  HI  DATE    DIR BAROM HUM
1    13.5  21.1   8/1/08   7.3   3/1/08 1386    0 17.00   3  38  23/1/08 WSW1021.36   73
2     0.0  14.9   1/3/08  14.9   1/3/08    0    0  0.00   0   6   1/3/08 ---  0.00    0
3    14.7  24.0   4/3/08   7.2   9/3/08 1425    0 15.00   5  54  24/3/08 WSW1008.77   59
4     0.0  21.6   3/5/08  21.6   3/5/08    0    0  0.00   0   0   3/5/08 ---  0.00    0
5    19.1  25.1   3/5/08  13.8   9/5/08  459    0  4.00   0   6  10/5/08 ENE1014.11   62
TOT  14.8  35.5  30/4/08   2.5   1/1/08 5999    0124.00   3  54  24/3/08 WSW1016.26   62
HEAT BASE: 65.0
COOL BASE: 65.0
Patxi
Re:NOAA support
Post by Patxi »
Is this funtion available with meteohub?
Vyborg
Re:NOAA support
Post by Vyborg »
yes, a NOAA report would be useful!
Vyborg
Re:NOAA support
Post by Vyborg »
up
trentinodoc
Re:NOAA support
Post by trentinodoc »
I am interested too! anyway who sold me meteohub told me that isn't possible to create NOAA reports. To do that is necessary disconnecting datalogger from meteohub and downloading data on weatherlink.
Isn't really impossible to have that .txt file?
Re:NOAA support
I know, Meteohub is a bit weak in creating monthly/yearly reports in HTML or NOAA style. I have it on my list, but at the moment I can't realize it for time reasons.
skyewright
Re:NOAA support
Post by skyewright »
trentinodoc wrote:To do that is necessary disconnecting datalogger from meteohub and downloading data on weatherlink.
Or you could use WD or WSWIN in conjunction with Meteohub. There is no need to disconnect Meteohub in either case and both can produce NOAA style reports?
David
trentinodoc
Re:NOAA support
David
how is it possible? somebody says it should be possible to do something like that.
I tried to download the weather data files recorded on meteohub from the Weatherlink but I couldn't... Do you know the right way to make them work together?
thank you
skyewright
Re:NOAA support
trentinodoc wrote:
I tried to download the weather data files recorded on meteohub from the Weatherlink but I couldn't... Do you know the right way to make them work together?[/quote]
I've no knowledge of weatherlink, but WeatherDisplay and WSWIN can both collect data from Meteohub, either continuously, or periodically.
I use WeatherDisplay and have it reading data from my Meteohub via the logging protocol.
The method for communicating with WSWIN is described in the Meteohub documentation.
David
