As I know very little about Linux, I would appreciate som help in how to copy my new Norwegian language file from my USB stick an onto the correct place in my Meteohub (ALIX 3d2) via the SSH interface
Thanks (I am still googling)
Geir
Copy lang file from USB stick?
Re: Copy lang file from USB stick?
I should had mentioned, I am on Mac, the name suggests to me that this is for Windows, but I will search for a Mac SCP client/software
I got in.... but seams to need more permissions... root? default password? (logged inn with meteohub/meteohub)
Fugu is to old for Lion, but I keep looking for other scp sw.
I have SFTP in transmit and can view files/folders but can not write/copy logging in with meteohub/meteohub, if I log in with root/meteohub I only see 4 files..
I did manage to copy the file to root (used terminal in Mac which supports scp) but..... in root there are only 4 files and my noorsk.lang file and I assume I should move it to some relevant directory?
Logging in with meteohub/meteohub I see lots of files and folders, but have nor rights to write.... ??
I see, I never played with that language file, because German was already there by default.
/public/graphs
can be accessed without SSH, it is part of meteohubs webserver directory and is also a windows share
so, from your MAC, you can reach it with
smb://your-meteohub-IP-Address/public
meteohub : meteohub (user : password)
graphs is one of the sub-directories
http://docs.info.apple.com/article.html ... /8849.html
/public/graphs
