i noitced this error message in the Meteohub log. I don't have a 'th1' sensor programed in Meteohub. Any ideas where I can look to get this removed? It happens ever 10 minutes.
wmr928eval (25.05.2008 13:58:01): no sensor found to match export name th1
wmr928eval (25.05.2008 14:08:00): no sensor found to match export name th1
wmr928eval (25.05.2008 14:18:00): no sensor found to match export name th1
wmr928eval (25.05.2008 14:28:01): no sensor found to match export name th1
wmr928eval (25.05.2008 14:38:00): no sensor found to match export name th1
wmr928eval (25.05.2008 14:48:01): no sensor found to match export name th1
wmr928eval (25.05.2008 14:58:00): no sensor found to match export name th1
th1 sensor not found message? ** solved **
skyewright
Re:th1 sensor not found message?
I have a feeling this has been mentioned before and that it somehow relates to settings in the WSWIN and/or WD export pages of the control panel? Perhaps th1 is a default setting there?
I don't use WD or WSWIN and there are no settings in those fields.
skyewright
I assumed you didn't - but what I wondered was if there was some low level default that applied if nothing else was set?cbhiii wrote:I don't use WD or WSWIN and there are no settings in those fields.
i.e. what if you set a 'good' value in there (maybe just for temp/hum outdoor, which is the most likely candidate for th1), but don't turn the 'on going' setting?
Just an idea...
Did i mention that I have this problem? Any ideas on this Boris? Thanks.
wmr928eval (01.06.2008 00:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 00:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 00:38:01): no sensor found to match export name th1
wmr928eval (01.06.2008 00:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 00:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 01:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 01:18:01): no sensor found to match export name th1
wmr928eval (01.06.2008 01:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 01:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 01:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 01:58:01): no sensor found to match export name th1
wmr928eval (01.06.2008 02:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 02:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 02:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 02:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 02:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 02:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 03:08:01): no sensor found to match export name th1
wmr928eval (01.06.2008 03:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 03:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 03:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 03:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 03:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 04:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 04:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 04:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 04:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 04:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 04:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 05:08:01): no sensor found to match export name th1
wmr928eval (01.06.2008 05:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 05:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 05:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 05:48:01): no sensor found to match export name th1
wmr928eval (01.06.2008 05:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 06:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 06:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 06:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 06:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 06:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 06:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 07:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 07:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 07:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 07:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 07:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 07:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 08:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 08:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 08:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 08:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 08:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 08:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 09:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 09:18:01): no sensor found to match export name th1
wmr928eval (01.06.2008 09:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 09:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 09:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 09:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 10:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 10:18:01): no sensor found to match export name th1
wmr928eval (01.06.2008 10:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 10:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 10:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 10:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 11:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 11:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 11:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 11:38:01): no sensor found to match export name th1
wmr928eval (01.06.2008 11:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 11:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 12:08:01): no sensor found to match export name th1
wmr928eval (01.06.2008 12:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 12:28:01): no sensor found to match export name th1
wmr928eval (01.06.2008 12:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 12:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 12:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 13:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 13:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 13:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 13:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 13:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 13:58:01): no sensor found to match export name th1
wmr928eval (01.06.2008 14:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 14:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 14:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 14:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 14:48:01): no sensor found to match export name th1
wmr928eval (01.06.2008 14:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 15:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 15:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 15:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 15:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 15:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 15:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 16:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 16:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 16:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 16:38:01): no sensor found to match export name th1
wmr928eval (01.06.2008 16:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 16:58:01): no sensor found to match export name th1
wmr928eval (01.06.2008 17:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 17:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 17:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 17:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 17:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 17:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 18:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 18:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 18:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 18:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 18:48:01): no sensor found to match export name th1
wmr928eval (01.06.2008 18:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 19:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 19:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 19:28:01): no sensor found to match export name th1
wmr928eval (01.06.2008 19:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 19:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 19:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 20:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 20:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 20:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 20:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 20:48:00): no sensor found to match export name th1
wmr928eval (01.06.2008 20:58:01): no sensor found to match export name th1
wmr928eval (01.06.2008 21:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 21:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 21:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 21:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 21:48:01): no sensor found to match export name th1
wmr928eval (01.06.2008 21:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 22:08:00): no sensor found to match export name th1
wmr928eval (01.06.2008 22:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 22:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 22:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 22:48:01): no sensor found to match export name th1
wmr928eval (01.06.2008 22:58:00): no sensor found to match export name th1
wmr928eval (01.06.2008 23:08:01): no sensor found to match export name th1
wmr928eval (01.06.2008 23:18:00): no sensor found to match export name th1
wmr928eval (01.06.2008 23:28:00): no sensor found to match export name th1
wmr928eval (01.06.2008 23:38:00): no sensor found to match export name th1
wmr928eval (01.06.2008 23:48:01): no sensor found to match export name th1
wmr928eval (01.06.2008 23:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 00:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 00:18:00): no sensor found to match export name th1
wmr928eval (02.06.2008 00:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 00:38:01): no sensor found to match export name th1
wmr928eval (02.06.2008 00:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 00:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 01:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 01:18:00): no sensor found to match export name th1
wmr928eval (02.06.2008 01:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 01:38:00): no sensor found to match export name th1
wmr928eval (02.06.2008 01:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 01:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 02:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 02:18:01): no sensor found to match export name th1
wmr928eval (02.06.2008 02:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 02:38:00): no sensor found to match export name th1
wmr928eval (02.06.2008 02:48:01): no sensor found to match export name th1
wmr928eval (02.06.2008 02:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 03:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 03:18:01): no sensor found to match export name th1
wmr928eval (02.06.2008 03:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 03:38:01): no sensor found to match export name th1
wmr928eval (02.06.2008 03:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 03:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 04:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 04:18:00): no sensor found to match export name th1
wmr928eval (02.06.2008 04:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 04:38:00): no sensor found to match export name th1
wmr928eval (02.06.2008 04:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 04:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 05:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 05:18:00): no sensor found to match export name th1
wmr928eval (02.06.2008 05:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 05:38:01): no sensor found to match export name th1
wmr928eval (02.06.2008 05:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 05:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 06:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 06:18:00): no sensor found to match export name th1
wmr928eval (02.06.2008 06:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 06:38:00): no sensor found to match export name th1
wmr928eval (02.06.2008 06:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 06:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 07:08:01): no sensor found to match export name th1
wmr928eval (02.06.2008 07:18:00): no sensor found to match export name th1
wmr928eval (02.06.2008 07:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 07:38:01): no sensor found to match export name th1
wmr928eval (02.06.2008 07:48:01): no sensor found to match export name th1
wmr928eval (02.06.2008 07:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 08:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 08:18:01): no sensor found to match export name th1
wmr928eval (02.06.2008 08:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 08:38:01): no sensor found to match export name th1
wmr928eval (02.06.2008 08:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 08:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 09:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 09:18:00): no sensor found to match export name th1
wmr928eval (02.06.2008 09:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 09:38:00): no sensor found to match export name th1
wmr928eval (02.06.2008 09:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 09:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 10:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 10:18:00): no sensor found to match export name th1
wmr928eval (02.06.2008 10:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 10:38:01): no sensor found to match export name th1
wmr928eval (02.06.2008 10:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 10:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 11:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 11:18:00): no sensor found to match export name th1
wmr928eval (02.06.2008 11:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 11:38:00): no sensor found to match export name th1
wmr928eval (02.06.2008 11:48:01): no sensor found to match export name th1
wmr928eval (02.06.2008 11:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 12:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 12:18:01): no sensor found to match export name th1
wmr928eval (02.06.2008 12:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 12:38:00): no sensor found to match export name th1
wmr928eval (02.06.2008 12:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 12:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 13:08:01): no sensor found to match export name th1
wmr928eval (02.06.2008 13:18:00): no sensor found to match export name th1
wmr928eval (02.06.2008 13:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 13:38:00): no sensor found to match export name th1
wmr928eval (02.06.2008 13:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 13:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 14:08:00): no sensor found to match export name th1
wmr928eval (02.06.2008 14:18:00): no sensor found to match export name th1
wmr928eval (02.06.2008 14:28:00): no sensor found to match export name th1
wmr928eval (02.06.2008 14:38:00): no sensor found to match export name th1
wmr928eval (02.06.2008 14:48:00): no sensor found to match export name th1
wmr928eval (02.06.2008 14:58:00): no sensor found to match export name th1
wmr928eval (02.06.2008 15:08:01): no sensor found to match export name th1
wmr928eval (02.06.2008 15:18:00): no sensor found to match export name th1
Hi there,
Just to say Boris reported this:
The warnings are not a problem. you can get the \"th1\" warning silent by going to the
wswin and wd export pages and setting values there as needed and pressing save
on both pages. That should do the job. I will have a look at this later on.
He must be busy adding some new features.. Remember I posted in Wishes it could be fine to have almanac feature. He said nothing, but here it is! :)
Chill
Chill
skyewright
Same for calibration offsets and multipliers for individual sensors. :)Chill wrote:He must be busy adding some new features.. Remember I posted in Wishes it could be fine to have almanac feature. He said nothing, but here it is! :)
Great guy that Boris. :cheer:
