I have no idea, how to send weather data to my server.
I set up the ftp information on the \"setup sending services\" (Sendedienste einrichten) and can upload the testfile, but there is no regulary upload of a data files. Obviously something is missing. I wonder which files are to be transfered at all.
I would also like the box to send an 15 minutes average instead of the every minute values.
Is the any scripting support in the meteohub (ideally perl, but phyton or php is also OK)
I am using the 2 GB image of meteohub. Is there any difference between the different sized images?
Thanks for help, Paul
How to transfer data via ftp?
Re:How to transfer data via ftp?
I will try to help you with the first part of FTP uploading. Under \"Graph Uploads\" you specify which files get uploaded and when they get uploaded based on the CRON Schedule column (see image below).
You first need to create and save graphs under the \"Define Graphs\" menu and then you can pick which ones are uploaded using this menu. The filename column is what you want the file to be called when it is on your FTP server. You can use the same name that you saved the graph under.
Thanks for the reply.
Unfortunately I don't understand how to transfer data, not images.
The Data-Items shown in your screenshot doesn't show up in my Meteohub. Obviously I have to edit the \"example\" entries in the pulldown list but don't know how to. (please see next post for a screenshot)
the promised screenshot
