Can't enable Dreamplug WLAN
Got the dreamplug. Followed the instructions to put meteohub on SD card. Managed to finally be able to access it by ethernet port.
access the meteo hub software via web-server interface. WLAN doesn't show up.
Went back to console -- ifconfig shows only eth0.
Rebooted off of the internal micro-SD. With the default debian from globalscaletechnologies, eth0, eth1 and uap0 are all visible under ifconfig. AP beacon is detected by laptop. (Which I could figure out how to make it start in client mode...)
Anyway, anyone know how I can get the WLAN to work under the meteohub boot off of the SDHC card?
(It's been a really long day!)
Kevin
Kevin
Re: Can't enable Dreamplug WLAN
I'm stunned that there have been no replies to this. Has anyone gotten the wifi to work with the dreamplug?
WLAN is only enabled when selected on the Meteohub network page and rebooted without a LAN cable connected.
Thanks. My problem is I can't find anywhere in the meteohub menus to enable it. The screen shots in the documentation show it on the same page as the LAN info. My screen show only the LAN. Is there somewhere else I need to go to do the enabling?
Then you don't have the expected WLAN module installed. In the Dreamplug sold in the beginning this is realized by an SD card sized WLAN module. Did you made any changes to that?
I bought from Globalscale and have made no changes. (Would have bought from the other source that sells the image along with it, but they didn't have a US option.) When it boots from the internal (non-SD) code, the wifi light turns on (blue) along with teh bluetooth light. It's been a couple of weeks, but I think my iphone saw the AP when it booted off of the internal code. (I remember I convinced myself that the hardware wasn't broken.)
I've seen places that have downloads for the internal boot code to enable AP mode, but I don't think that is what I want or need, so I haven't gotten that. I haven't had the unit apart, so I don't know what the hardware is.
When it boots from the meteohub image the WLAN light stays dark. From command line, ifconfig doesn't seem to see the wifi. (not sure if it is supposed to.)
WLAN does show up with my Dreamplug, when I use the specialized Meteohub DreamPlug image.
I don't know why it does not with your.
Trying to figure out why Meteohub can't see my WLAN hardware. Anything I can pull off of the unit that will help us debug this?
could you please post a screendump of "system info" page and the output of "dmesg log" on log files page?
Here is my system info from unit:
SoftwareLinux Kernel: 2.6.32 1192 BogoMIPS, 515 MB RAM, DreamPlug
MeteoHub: 4.8i (Build 906) ©2011 by smartbedded UG (haftungsbeschränkt)
System ID: BZ@0KXN4 activated
I started with the 4.7 dreamplug image and upgraded from within the application.
I rebooted.
Here is my DMESG log. See anything that looks odd?
DMESG:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-5-kirkwood (Debian 2.6.32-13) (maks@debian.org) (gcc version 4.3.4 (Debian 4.3.4-10) ) #1 Fri May 21 05:44:29 UTC 2010
[ 0.000000] CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: Marvell GuruPlug Reference Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat c03db168, node_mem_map c0cfa000
[ 0.000000] Normal zone: 1024 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 130048 pages, LIFO batch:31
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: console=ttyS0,115200 root=/dev/sdb2 rootdelay=10
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 256MB 256MB = 512MB total
[ 0.000000] Memory: 509952KB available (3548K code, 583K data, 120K init, 0K highmem)
[ 0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:114
[ 0.000000] Console: colour dummy device 80x30
[ 21.474958] Calibrating delay loop... 1192.75 BogoMIPS (lpj=5963776)
[ 21.714914] Security Framework initialized
[ 21.714932] SELinux: Disabled at boot.
[ 21.714953] Mount-cache hash table entries: 512
[ 21.715206] Initializing cgroup subsys ns
[ 21.715218] Initializing cgroup subsys cpuacct
[ 21.715227] Initializing cgroup subsys devices
[ 21.715235] Initializing cgroup subsys freezer
[ 21.715243] Initializing cgroup subsys net_cls
[ 21.715275] CPU: Testing write buffer coherency: ok
[ 21.715811] devtmpfs: initialized
[ 21.717254] regulator: core version 0.5
[ 21.717424] NET: Registered protocol family 16
[ 21.717812] Kirkwood: MV88F6281-A1, TCLK=200000000.
[ 21.717824] Feroceon L2: Cache support initialised.
[ 21.718214] initial MPP regs: 01112222 11113311 33331111 33333333 00003333 00000222 00000000
[ 21.718236] final MPP regs: 01112222 11113311 33331111 33333333 00003333 00000222 00000000
[ 21.719902] bio: create slab <bio-0> at 0
[ 21.720188] vgaarb: loaded
[ 21.720650] Switching to clocksource orion_clocksource
[ 21.724415] NET: Registered protocol family 2
[ 21.724652] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 21.725485] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 21.725839] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 21.726019] TCP: Hash tables configured (established 16384 bind 16384)
[ 21.726028] TCP reno registered
[ 21.726178] NET: Registered protocol family 1
[ 21.726352] Unpacking initramfs...
[ 22.060984] Freeing initrd memory: 5092K
[ 22.061082] NetWinder Floating Point Emulator V0.97 (double precision)
[ 22.061334] audit: initializing netlink socket (disabled)
[ 22.061384] type=2000 audit(0.580:1): initialized
[ 22.067986] VFS: Disk quotas dquot_6.5.2
[ 22.068257] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 22.068357] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 22.068956] msgmni has been set to 1006
[ 22.070651] alg: No test for stdrng (krng)
[ 22.070810] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 22.070823] io scheduler noop registered
[ 22.070830] io scheduler anticipatory registered
[ 22.070838] io scheduler deadline registered
[ 22.071018] io scheduler cfq registered (default)
[ 22.076992] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 22.077450] serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A
[ 22.395195] console [ttyS0] enabled
[ 22.399262] No NAND device found!!!
[ 22.403380] mice: PS/2 mouse device common for all mice
[ 22.408977] rtc-mv rtc-mv: rtc core: registered rtc-mv as rtc0
[ 22.414944] i2c /dev entries driver
[ 22.418643] cpuidle: using governor ladder
[ 22.422911] cpuidle: using governor menu
[ 22.426972] Registered led device: guruplug:red:health
[ 22.432217] Registered led device: guruplug:green:health
[ 22.437613] Registered led device: guruplug:red:wmode
[ 22.442769] Registered led device: guruplug:green:wmode
[ 22.448068] mv_xor_shared mv_xor_shared.0: Marvell shared XOR driver
[ 22.454481] mv_xor_shared mv_xor_shared.1: Marvell shared XOR driver
[ 22.500720] mv_xor mv_xor.0: Marvell XOR: ( xor cpy )
[ 22.540717] mv_xor mv_xor.1: Marvell XOR: ( xor fill cpy )
[ 22.580716] mv_xor mv_xor.2: Marvell XOR: ( xor cpy )
[ 22.620715] mv_xor mv_xor.3: Marvell XOR: ( xor fill cpy )
[ 22.627385] TCP cubic registered
[ 22.630629] NET: Registered protocol family 17
[ 22.635127] Gating clock of unused units
[ 22.635135] before: 0x00dfc3fd
[ 22.635142] after: 0x00cf41d9
[ 22.635466] registered taskstats version 1
[ 22.640265] rtc-mv rtc-mv: setting system clock to 2012-01-08 14:58:58 UTC (1326034738)
[ 22.648322] Initalizing network drop monitor service
[ 22.653380] Freeing init memory: 120K
[ 23.026183] mmc0: mvsdio driver initialized, lacking card detect (fall back to polling)
[ 23.100493] mmc0: new high speed SDIO card at address 0001
[ 24.160876] usbcore: registered new interface driver usbfs
[ 24.172571] usbcore: registered new interface driver hub
[ 24.180731] usbcore: registered new device driver usb
[ 24.201958] SCSI subsystem initialized
[ 24.245043] MV-643xx 10/100/1000 ethernet driver version 1.4
[ 24.253315] mv643xx_eth smi: probed
[ 24.340218] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 24.386586] net eth0: port 0 with MAC address f0:ad:4e:00:e1:9f
[ 24.392670] orion-ehci orion-ehci.0: Marvell Orion EHCI
[ 24.397971] orion-ehci orion-ehci.0: new USB bus registered, assigned bus number 1
[ 24.422643] libata version 3.00 loaded.
[ 24.500729] orion-ehci orion-ehci.0: irq 19, io mem 0xf1050000
[ 24.520739] orion-ehci orion-ehci.0: USB 2.0 started, EHCI 1.00
[ 24.526744] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 24.533601] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 24.540870] usb usb1: Product: Marvell Orion EHCI
[ 24.545600] usb usb1: Manufacturer: Linux 2.6.32-5-kirkwood ehci_hcd
[ 24.551996] usb usb1: SerialNumber: orion-ehci.0
[ 24.593349] usb usb1: configuration #1 chosen from 1 choice
[ 24.599522] hub 1-0:1.0: USB hub found
[ 24.603373] hub 1-0:1.0: 1 port detected
[ 24.694792] net eth1: port 0 with MAC address f0:ad:4e:00:e1:a0
[ 24.700887] sata_mv sata_mv.0: version 1.28
[ 24.705161] sata_mv sata_mv.0: slots 32 ports 1
[ 24.730127] scsi0 : sata_mv
[ 24.736477] ata1: SATA max UDMA/133 irq 21
[ 24.920697] usb 1-1: new high speed USB device using orion-ehci and address 2
[ 25.071254] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[ 25.077985] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 25.085165] usb 1-1: Product: USB 2.0 Hub
[ 25.090305] usb 1-1: configuration #1 chosen from 1 choice
[ 25.095882] ata1: SATA link down (SStatus 0 SControl F300)
[ 25.111215] hub 1-1:1.0: USB hub found
[ 25.120763] hub 1-1:1.0: 4 ports detected
[ 25.410789] usb 1-1.1: new high speed USB device using orion-ehci and address 3
[ 25.522628] usb 1-1.1: New USB device found, idVendor=05e3, idProduct=0726
[ 25.529541] usb 1-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[ 25.536895] usb 1-1.1: Product: USB Storage
[ 25.541131] usb 1-1.1: SerialNumber: 000000009910
[ 25.547039] usb 1-1.1: configuration #1 chosen from 1 choice
[ 25.620216] Initializing USB Mass Storage driver...
[ 25.627035] scsi1 : SCSI emulation for USB Mass Storage devices
[ 25.633188] usb 1-1.2: new low speed USB device using orion-ehci and address 4
[ 25.641701] usbcore: registered new interface driver usb-storage
[ 25.648496] usb-storage: device found at 3
[ 25.648505] usb-storage: waiting for device to settle before scanning
[ 25.650342] USB Mass Storage support registered.
[ 25.769268] usb 1-1.2: New USB device found, idVendor=1941, idProduct=8021
[ 25.776192] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 25.784681] usb 1-1.2: configuration #1 chosen from 1 choice
[ 25.874196] usb 1-1.4: new full speed USB device using orion-ehci and address 5
[ 25.889650] usbcore: registered new interface driver hiddev
[ 25.909891] generic-usb 0003:1941:8021.0001: hiddev0,hidraw0: USB HID v1.00 Device [HID 1941:8021] on usb-orion-ehci.0-1.2/input0
[ 25.923451] usbcore: registered new interface driver usbhid
[ 25.931626] usbhid: v2.6:USB HID core driver
[ 25.992001] usb 1-1.4: New USB device found, idVendor=0d8c, idProduct=000c
[ 25.998912] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 26.006271] usb 1-1.4: Product: C-Media USB Headphone Set
[ 26.013037] usb 1-1.4: configuration #1 chosen from 1 choice
[ 26.033156] input: C-Media USB Headphone Set as /devices/platform/orion-ehci.0/usb1/1-1/1-1.4/1-1.4:1.3/input/input0
[ 26.131469] generic-usb 0003:0D8C:000C.0002: input,hidraw1: USB HID v1.00 Device [C-Media USB Headphone Set ] on usb-orion-ehci.0-1.4/input3
[ 30.641202] usb-storage: device scan complete
[ 30.661838] scsi 1:0:0:0: Direct-Access Generic STORAGE DEVICE 9910 PQ: 0 ANSI: 0
[ 30.670427] scsi 1:0:0:1: Direct-Access Generic STORAGE DEVICE 9910 PQ: 0 ANSI: 0
[ 30.796298] sd 1:0:0:0: [sda] 7744512 512-byte logical blocks: (3.96 GB/3.69 GiB)
[ 30.806287] sd 1:0:0:0: [sda] Write Protect is off
[ 30.811167] sd 1:0:0:0: [sda] Mode Sense: 0b 00 00 08
[ 30.811177] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 30.817793] sd 1:0:0:1: [sdb] 7837696 512-byte logical blocks: (4.01 GB/3.73 GiB)
[ 30.827049] sd 1:0:0:1: [sdb] Write Protect is off
[ 30.831914] sd 1:0:0:1: [sdb] Mode Sense: 0b 00 00 08
[ 30.831924] sd 1:0:0:1: [sdb] Assuming drive cache: write through
[ 30.841400] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 30.847530] sda: sda1 sda2
[ 30.864176] sd 1:0:0:1: [sdb] Assuming drive cache: write through
[ 30.870306] sdb:
[ 30.875044] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 30.881387] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 30.889196] sdb1 sdb2 sdb3 sdb4
[ 30.899420] sd 1:0:0:1: [sdb] Assuming drive cache: write through
[ 30.905596] sd 1:0:0:1: [sdb] Attached SCSI removable disk
[ 35.291115] md: linear personality registered for level -1
[ 35.322912] md: multipath personality registered for level -4
[ 35.355076] md: raid0 personality registered for level 0
[ 35.393676] md: raid1 personality registered for level 1
[ 35.423925] async_tx: api initialized (async)
[ 35.439770] xor: measuring software checksum speed
[ 35.490674] arm4regs : 1085.200 MB/sec
[ 35.540675] 8regs : 804.400 MB/sec
[ 35.590673] 32regs : 900.800 MB/sec
[ 35.594870] xor: using function: arm4regs (1085.200 MB/sec)
[ 35.781151] raid6: int32x1 78 MB/s
[ 35.951095] raid6: int32x2 103 MB/s
[ 36.120909] raid6: int32x4 124 MB/s
[ 36.290849] raid6: int32x8 110 MB/s
[ 36.294615] raid6: using algorithm int32x4 (124 MB/s)
[ 36.334798] md: raid6 personality registered for level 6
[ 36.340142] md: raid5 personality registered for level 5
[ 36.345521] md: raid4 personality registered for level 4
[ 36.479487] md: raid10 personality registered for level 10
[ 36.748220] kjournald starting. Commit interval 5 seconds
[ 36.753812] EXT3-fs: mounted filesystem with ordered data mode.
[ 38.126328] udevd version 125 started
[ 43.358913] usbcore: registered new interface driver snd-usb-audio
[ 45.166125] Adding 119156k swap on /dev/sdb3. Priority:-1 extents:1 across:119156k
[ 45.284797] EXT3 FS on sdb2, internal journal
[ 46.735054] loop: module loaded
[ 47.589226] kjournald starting. Commit interval 120 seconds
[ 47.596524] EXT3 FS on sdb4, internal journal
[ 47.600931] EXT3-fs: mounted filesystem with ordered data mode.
[ 49.526068] NET: Registered protocol family 10
[ 49.544509] lo: Disabled Privacy Extensions
[ 49.550316] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 49.813935] eth0: link up, 100 Mb/s, full duplex, flow control disabled
[ 49.820819] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 52.212063] usbcore: registered new interface driver usbserial
[ 52.225005] USB Serial support registered for generic
[ 52.233462] usbcore: registered new interface driver usbserial_generic
[ 52.240027] usbserial: USB Serial Driver core
[ 52.262058] USB Serial support registered for pl2303
[ 52.272378] usbcore: registered new interface driver pl2303
[ 52.277977] pl2303: Prolific PL2303 USB to serial adaptor driver
[ 52.687350] USB Serial support registered for cp210x
[ 52.697642] usbcore: registered new interface driver cp210x
[ 52.703319] cp210x: v0.09:Silicon Labs CP210x RS232 serial adaptor driver
[ 52.826826] USB Serial support registered for FTDI USB Serial Device
[ 52.838766] usbcore: registered new interface driver ftdi_sio
[ 52.844580] ftdi_sio: v1.5.0:USB FTDI Serial Converters Driver
[ 52.964248] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 55.858344] warning: `ntpd' uses 32-bit capabilities (legacy support in use)
[ 60.400555] eth0: no IPv6 routers present
USB:
Bus 001 Device 005: ID 0d8c:000c C-Media Electronics, Inc. Audio Adapter
Bus 001 Device 004: ID 1941:8021 Dream Link USB Missile Launcher
Bus 001 Device 003: ID 05e3:0726 Genesys Logic, Inc.
Bus 001 Device 002: ID 1a40:0101 TERMINUS TECHNOLOGY INC. USB-2.0 4-Port HUB
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
PCI:
Partitions:
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sdb2 858832 676908 138308 84% /
tmpfs 257768 0 257768 0% /lib/init/rw
udev 10240 480 9760 5% /dev
tmpfs 257768 0 257768 0% /dev/shm
/dev/sdb4 2603128 88576 2382320 4% /data
tmpfs 8192 0 8192 0% /var/lock
tmpfs 32768 1308 31460 4% /var/run
tmpfs 32768 16 32752 1% /var/log
Process:
PID TTY STAT TIME COMMAND
1 ? Ss 0:00 init [2]
2 ? S 0:00 [kthreadd]
3 ? S 0:00 [ksoftirqd/0]
4 ? S 0:00 [watchdog/0]
5 ? S 0:00 [events/0]
6 ? S 0:00 [cpuset]
7 ? S 0:00 [khelper]
8 ? S 0:00 [netns]
9 ? S 0:00 [async/mgr]
10 ? S 0:00 [pm]
11 ? S 0:00 [sync_supers]
12 ? S 0:00 [bdi-default]
13 ? S 0:00 [kintegrityd/0]
14 ? S 0:00 [kblockd/0]
15 ? S 0:00 [kseriod]
16 ? S 0:00 [khungtaskd]
17 ? S 0:00 [kswapd0]
18 ? SN 0:00 [ksmd]
19 ? S 0:00 [aio/0]
20 ? S 0:00 [crypto/0]
25 ? S 0:00 [mtdblockd]
26 ? S 0:00 [orion_spi]
27 ? S 0:00 [kpsmoused]
64 ? S 0:00 [kmmcd]
254 ? S 0:00 [ksuspend_usbd]
258 ? S 0:00 [khubd]
273 ? S 0:00 [ata/0]
277 ? S 0:00 [ata_aux]
298 ? S 0:00 [scsi_eh_0]
318 ? S 0:00 [scsi_eh_1]
319 ? S 0:00 [usb-storage]
331 ? S 0:00 [usbhid_resumer]
499 ? S 0:00 [kjournald]
586 ? S<s 0:00 udevd --daemon
945 ? S 0:00 [mv_crypto]
1043 ? Ss 0:00 logsave -s /var/log/fsck/checkroot fsck -C -y -t ext3 /dev/sdb2
1132 ? S 0:00 [flush-8:16]
1159 ? Ss 0:00 logsave -s /var/log/fsck/checkfs fsck -C -R -A -y
1171 ? S 0:00 [kjournald]
1278 ? Ss 0:00 /sbin/portmap
1289 ? Ss 0:00 /sbin/rpc.statd
1431 ? S 0:00 /home/meteohub/meteoschedule /dev/meteohub
1477 ? Sl 0:00 /usr/sbin/rsyslogd -f /etc/syslog.conf
1493 ? Ss 0:00 /usr/bin/dbus-daemon --system
1507 ? Ss 0:00 /usr/sbin/sshd
1530 ? S 0:06 /home/meteohub/meteonet -r
1610 ? Ss 0:00 /usr/bin/rsync /var/run/rsyncd.pid --daemon
1615 ? Ss 0:00 /usr/sbin/nmbd -D
1617 ? Ss 0:00 /usr/sbin/smbd -D
1626 ? S<s 0:00 /usr/sbin/thttpd -C /etc/thttpd.conf
1628 ? S<s 0:00 /usr/sbin/thttpdbackup -C /etc/thttpd-backup.conf
1636 ? Ss 0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -u 105:107 -g
1640 ? S 0:00 /usr/sbin/smbd -D
1647 ? Ss 0:00 /sbin/mdadm --monitor --pid-file /var/run/mdadm/monitor.pid --daemonise --scan --syslog
1667 ? Ss 0:00 /usr/sbin/cron
1677 ? SLs 0:00 /usr/sbin/watchdog
1690 ttyS0 Ss+ 0:00 /sbin/getty -L ttyS0 115200 linux
3299 ? S< 0:00 /home/meteohub/loggerd /var/run/loggerd.pid
3300 ? S< 0:01 /home/meteohub/loggerd /var/run/loggerd.pid
3351 ? S< 0:00 /home/meteohub/hidlog6 6 19208503290059
3352 ? Z< 0:00 [sh] <defunct>
11809 ? S< 0:00 meteohub.cgi
11810 ? Z< 0:00 [thttpd] <defunct>
11811 ? S< 0:00 /usr/sbin/thttpd -C /etc/thttpd.conf
11820 ? Z 0:00 [watchdog] <defunct>
11844 ? R< 0:00 ps ax
DMESG:
[ 30.870306] sdb:
USB:
PCI:
Partitions:
Process:
6 ? S 0:00 [cpuset]
8 ? S 0:00 [netns]
10 ? S 0:00 [pm]
18 ? SN 0:00 [ksmd]
19 ? S 0:00 [aio/0]
64 ? S 0:00 [kmmcd]
To make sure the updates are not the problem, I installed a fresh 4.7 image on the DreamPlug's SD card and upgraded to 4.9.
both version do show WLAN options. Comparing my dmesg with yours I have a sequence about loading "libertas" driver, that cannot be ssen in your dmesg listing:
Sorry, but no idea why your system behaves different.
When you browse to "http://ip-of-your-meteohub/cgi-bin/help.cgi" to open a ssh tunnel I might be able to login and check some things directly.
[ 38.158506] udevd version 125 started
[ 42.804034] usbcore: registered new interface driver snd-usb-audio
[ 43.610697] lib80211: common routines for IEEE802.11 drivers
[ 43.616386] lib80211_crypt: registered algorithm 'NULL'
[ 43.707315] libertas_sdio: Libertas SDIO driver
[ 43.711936] libertas_sdio: Copyright Pierre Ossman
[ 43.719231] libertas_sdio mmc0:0001:1: firmware: requesting sd8688_helper.bin
[ 43.770583] Bluetooth: Core ver 2.15
[ 43.776329] NET: Registered protocol family 31
[ 43.780862] Bluetooth: HCI device and connection manager initialized
[ 43.787244] Bluetooth: HCI socket layer initialized
[ 43.888019] libertas_sdio mmc0:0001:1: firmware: requesting sd8688.bin
[ 45.268696] libertas: 00:24:23:39:0c:7a, fw 10.38.3p49, cap 0x00000303
[ 45.338758] libertas: wlan0: Marvell WLAN 802.11 adapter
[ 45.344235] Bluetooth: vendor=0x2df, device=0x9105, class=255, fn=2When you browse to "http://ip-of-your-meteohub/cgi-bin/help.cgi" to open a ssh tunnel I might be able to login and check some things directly.
Opened the tunnel. Let me know if you can see anything.
It appears that globalscale has changed to the marvell 8787 part
http://www.newit.co.uk/forum/index.php/ ... 741.0.html
I have the same symptom as this person.
should this be as simple as putting the correct .bin files in and loading the libertas module?
Sounds very reasonable. I found the attached firmware for this device. Please unzip and copy resulting bin file into folder /lib/firmware and reboot. I hope this fixes it.
- sd8787_uapsta.zip
- (252.45 KiB) Downloaded 730 times
