Update 4.9
What's hot...
Update 4.9
Update to Meteohub V4.9 (NSLU2, x86, SheevaPlug, DreamPlug, iConnect) brings these features:
  • Adds some info on system page about wear status of used flash media. This status just reflects wear generated by Meteohub (starting with version 4.9) use, Wear that happened to the stick before use with Meteohub v4.9 or later is not taken into account. Approximated wear is given in rounds. One round is equivalent to writing every block of the flash media one time. SLC flash accompanied with a good wear leveling algortihm should stand a few thousand rounds. Cheap MLC usb sticks with inferior wear leveling are at risk to start failing after 100 rounds.
  • Supports USB stick clone function on iConnect. Simply insert a second stick during normal Meteohub operation and press front button until LED over inserted new USB stick starts flashing. Wait until flashing has finished and LED is turned off. Now the new stick can be removed. It is ready for operation now. You will also find some messages in "meteohub log".
  • Adds support for Lux/Solar and UV sensors of WH-3080 station to generic WH-1080 driver.
  • Fixes a bug that counts too many rain days and temperature ranges when timezone is not GMT.
  • Enhances rain day counting by ignoring a "rainfall" up to 1 mm per day. This clip level prevents a few drops of dew moisture to count a otherwise dry day as a day with rain. Changes apply to your logged data after a recompute.
  • Fixes a bug that does not stop upload of live data to Meteplug server although live data upload has been disabled.
  • Evaluation period has been extended until end of July 2012.
Update Link: http://www.meteohub.de/files/update-v4.9.upd
You also find updated v4.9 images for SheevaPlug, DreamPlug, iConnect and x86 platforms (alix, ebox, fitPC) here: http://wiki.meteohub.de/Images
clarin
Re: Update 4.9
Post by clarin »
Since the update, my iWDL mobile phone webapp isn't reading my clientraw.txt
https://www.poeiti.ch/iwdl/#home
Any ideas?
Thanks & regards,
Clarin
wfpost
Re: Update 4.9
Post by wfpost »
Updated to 4.9 :: mine is working ...
http://bit.ly/mobhon
that parser says that your clientraw.txt seems to be corrupt :wink:
http://www.tnetweather.com/wd-parser.ph ... mit=Submit
maybe you recreate a new clientraw.conf in pressing save (speichern) with the
WD /MW Live menu
clarin
Re: Update 4.9
Post by clarin »
I rebooted and it all went back to normal...
Thanks for your help
Billy
Re: Update 4.9
Post by Billy »
@ Boris
Is the support for cloning USB sticks on iConnect also valid for SD cards connected via suitable SD card readers? :roll:
Regards Billy
Re: Update 4.9
Yes, a SD card inside a USB SD card reader acts exactly as a USB stick.
orf1
Re: Update 4.9
Post by orf1 »
Is enabled the 1mm rainfall limit in all cases or can been disabled?
Re: Update 4.9
always on.
rain totals do not suffer from this, only classification of days does change a bit.
orf1
Re: Update 4.9
Post by orf1 »
Ok Thanks.
I'm worried for the rain totals. If all rain is computed, not problem at all.
wfpost
Re: Update 4.9
Post by wfpost »
admin wrote:Update to Meteohub V4.9 (NSLU2, x86, SheevaPlug, DreamPlug, iConnect) brings these features:
[*] Enhances rain day counting by ignoring a "rainfall" up to 1 mm per day. This clip level prevents a few drops of dew moisture to count a otherwise dry day as a day with rain. Changes apply to your logged data after a recompute.
For the current month it shows
month1_rain0_days 20
But my daily rain for January is as follows and would make 10 rain days.
Seems this nice and good feature does not work?!?
My meteohub is still on 4.9. Would an update to 4.9c fix it?
  • 2011.01.01 --> 2.8 (*)
    2011.01.02 --> 0.2
    2011.01.03 --> 0.0
    2011.01.04 --> 7.6 (*)
    2011.01.05 --> 3.2 (*)
    2011.01.06 --> 0.6
    2011.01.07 --> 2.8 (*)
    2011.01.08 --> 0.8
    2011.01.09 --> 2.6 (*)
    2011.01.10 --> 1.6 (*)
    2011.01.11 --> 0.2
    2011.01.12 --> 0.4
    2011.01.13 --> 0.0
    2011.01.14 --> 0.4
    2011.01.15 --> 0.0
    2011.01.16 --> 0.0
    2011.01.17 --> 0.0
    2011.01.18 --> 0.0
    2011.01.19 --> 4.6 (*)
    2011.01.20 --> 0.2
    2011.01.21 --> 0.6
    2011.01.22 --> 3.2 (*)
    2011.01.23 --> 7.2 (*)
    2011.01.24 --> 2.8 (*)
    2011.01.25 --> 0.4
    2011.01.26 --> 0.2
