EmjayNet
Post by EmjayNet »
This morning I was adding a new virtual sensor, on MH (ALIX 3D2) added the first part sensdiffmaster, click Save & Restart I got:
Warning: Data logging has been halted.
S**t, can I be losing a Transcend TS4GCF100I after only 1 year 3 months service?
Ok jumped into action created a new image on my brand new spare Transcend TS4GCF100I and started to setup the station again.
Got card setup, copied over by backup that ICW takes every night and away we go!
The last bit I did was assign the sensor ID and name clicked 'Save and Restart', again:
There is nothing in the MH log to show there’s any problem with the card!
As part of the rebuild I need to add more virtual sensors to get my website work again but I'm worried about this error if I hit 'save & restart' again.
MH does continue to work after the error but it is very worrying.
Is my Davis data logger on the way, is it a problem in MH, I need some Help please!!!
Mark
Re: error connect socket 127.0.0.1:5555 :Connection refused
During restart of the logger this error message can appear. It should fade if you press refresh.
EmjayNet
Post by EmjayNet »
Ok, thanks for putting my mind at rest! :D
