Have you got my private message?d_l wrote:I had to break it down and zip it to be under the permitted size limit and in an allowable format.
THSW index
Re: THSW index
Best Regards
Hathor27
http://untersiggenthal.meteodata.ch
Hathor27
Re: THSW index
Oops, I'd overlooked it. The whole PDF is the VP1 version of AN 28 and only in a few instances such as THSW index calculations does it differ at all from the information contained in AN 28. For some reason, it is vastly more bloated in size than the AN 28. pdf.Hathor27 wrote: Have you got my private message?
Re: THSW index
Thank you, d_ld_l wrote:Oops, I'd overlooked it. The whole PDF is the VP1 version of AN 28 and only in a few instances such as THSW index calculations does it differ at all from the information contained in AN 28. For some reason, it is vastly more bloated in size than the AN 28. pdf.Hathor27 wrote: Have you got my private message?
Do you think Davis would mind if I load it onto my webserver and grant access for download for people of our community?
Best Regards
Hathor27
Hathor27
Re: THSW index
I don't know. It probably would be ok as long as you referenced the more recent AN 28.pdf and also mentioned that some of the look up tables and formulas might be revised in the latest firmware and software versions.Hathor27 wrote: Do you think Davis would mind if I load it onto my webserver and grant access for download for people of our community?
