Creating and sending url
I was wondering: is it possible to create a url and call this url automaticly. Why?
I live in Hungary, i want to upload my wheaterdata to http://www.idokep.hu. This can be done with a program of them but this works only with my computer turned on. I asked them for an other solution and this is there answer:
To upload data to Idokep, You also have to register to Idokep Pro (pro.idokep.hu), with the same username/password as You used when registering for Idokep.
Then, you'll have to upload real-time data (preferrably in every minute), by calling the url below (as if it was a website url)
http://pro.idokep.hu/sendws.php?user=us ... okes=0.0
Of course, in the aboeve example, You will have to insert Your own username/password, as well as the actual weather data.
user=username
pass=password
tipus=your_weather_station_type
p=sea_level_air_pressure
hom=temperature
rh=humidity
szelero=wind_speed (in m/s)
szelirany=wind_direction (degrees 0-359)
csap1h=rain_in_last_hour (in mm)
csap=rain_in_last_day (in mm)
szellokes=wind_gust (in m/s).
Anyone ideas?
user=username
pass=password
hom=temperature
rh=humidity
Anyone ideas?
Re: Creating and sending url
I can try to add support for this weather network in one of the next updates.
Would be great!
Thank you!
Thank you!
Please try the update located here, you will find a new enty for this network on weather network page:
http://meteohub.de/files/update-v4.9x.upd
Place on the smb share /public/transfer/, install method "file": /data/transfer/update-v4.9x.upd
Great job Boris, thank you.
Update is up and running. Seems to work fine. For now just one issue: after every succesful upload to idokep.hu (5 minuts interval) I reseve an error e-mail from Meteohub:
Anyway great job, thanks a lot!
Jos
For now I set upload messages to 'once an day'.Meteohub (meteohub): Cannot connect to Weather Network "idokep"
upload to idokep: Feltoltes sikeres <b><a target=_blank href=http://pro.idokep.hu/summary/index/id/1 ... iko</a></b> allomas nevvel<br>Archiv adatok lekerdezhetoek <a target=_blank href=http://pro.idokep.hu/graph/index/id/1107>itt</a> (10 perccel az elso adatfeltoltes utan) <!-- Beírás ide:<br> --!>
Jos
I did't took the time to translate de Hungarian part of the e-mail. The replay mail is not an error massage but an confirmation of a succesfull upload.
Translation in english:
Anyway I set the email notification to once a day, otherwise my mailbox explodes.
Jos
This is the html page where you normally will returned to after submitting de url with (wheater-)data in browser.Upload a successful <b> <a target=_blank href=http://pro.idokep.hu/summary/index/id/1107> idociko </ a> </ b> Station name <br> archive data can be queried <a target = _blank href = http://pro.idokep.hu/graph/index/id/1107> here </ a> (10 minutes after the first upload) <! - Sign here: <br> ->
Jos
Upload process does expect to get an "OK" or "Success" in the string.
As I can't read Hungarian, what is the part of the string the process should look for to be sure upload has worked fine?
Looks like "sikeres" is the word for successful, so I will check for this one.
I uploaded a new 4.9x, please give it a try.
"Feltoltes sikeres" means "Upload succeded".
I'm sorry, but where can I find 4.9x ?
I just replaced the one you already installed.
4.9x is running now for 15 minutes. No email notifications!
Thanks again
Thanks again
I think windspeed and gust are uploaded to idokep.hu in km/h. This must be m/s
Idökép convert m/s to km/h. Now the windspeed and gust are because of this mutch to high. (factor 3.6)
I could't see this yesterday because there was no wind at all then.
Uploaded a new 4.9x which should have that fixed. Please give it a try.
Works fine now!
Thanks again.
Jos
Thanks again.
Jos
