hi forum,
does anyone know, if there are sensors (windspeed, winddirection, temperature, pressure ), with an usb interface, so that I can directly connect the sensor to an a lix board? I don't need a display, I will mount all together anywhere in the mountain with a solar panel
cu
usb only sensor for alix board
Re: usb only sensor for alix board
did you have a look at this solution? Although pressure reading is not posible then.
http://www.smartbedded.com/wiki/index.p ... -_Meteohub
hi,
yes, I found tis solution, but I also need the pressure (and temp)
I will need the station for paragliding, we want to know, if we should go up or not
cu
cu
you could add an 1-wire baro.
As far as I recall 1-wire should work with meteohub
http://davidbray.org/onewire/
toradex provides a cheap USB pressure sensor supported by meteohub. one wire is not oficially supported but some users have added support for it themself.
hi again,
so there is an usb-air-presure. sensor http://www.toradex.com/de/En/Products/U ... c_Pressure
now I look for the rest, maybe there is an allinone Sensor für windspeed, wind direction and temperature with an usb interface...
cu
cu
please let me know, if you find some...
