Reset Weather Data
Reset Weather Data
How do you go about resetting the weather data? Now that my weather station is all setup I need to clear the erroneous readings.
Re: Reset Weather Data
I found this:
viewtopic.php?f=8&t=8470
1) Disable Data Logging under Maintenance
2) Under Inspect Data enter the UTC date range
....this is where I get the message back that "0 data records between timestamps 20120813144132 and 19440726112723 (UTC) have been marked as deleted.", but that's not the end range I entered. Can someone tell me what the entries should look like?
I can't figure out how to use the web interface to delete the data.You can delete the monthly folders in /public/weather/ named "yyyymm" when accessing these from your PC via Meteohubs PC-Networkdrive (user meteohub, password meteohub).
As an alternative you can mark the past data as deleted by features of "inspect data" page of Meteohub. Needs to be done sperately for each month.
OK, I got them to be marked by an " * ". how are they removed?
- YJB
I would not really worry too much and do this directly from the share access to MH (marking individual records is a kind of tedious process and is normally only useful when few records are bad).
Stop data logging (from the web interface)
Go to \\<meteohub ip\public\shares\weather
Delete all directories underneath (or remove the raw files)
Initiate a recompute (to remove all the aggregations)
Start data logging.
Ysbrand
Start data logging.
Ysbrand
