UVN800 Sensor does not allow to create a UVI-max or min grap
This is intended for WMR100, WMR200, WMRS200 and RMS300 specific topics
wfpost
Post by wfpost »
I tried to create a graph with the UVI Sensor and selected the uv-0-max (UV-I) sensor.
Following error message appears:
plot '< /srv/www/cgi-bin/goto.cgi (null)0-min5 2008062700000000' using 1:0 axis x1y1 title "UV-Index" with boxes linecolor rgb "#ff0000"
"/tmp/meteobF1cjE", line 33: warning: Skipping data file with no valid points
"/tmp/meteobF1cjE", line 33: all points y value undefined!
Content-type: image/png
Same with uv-0-min (UV-I)
Only uv-0 (UV-I) works fine and creates the graph.
What´s the reason for this error?
The values are there, because I poll the daily max UVI value and write it to my webpage. That works fine. Image
wfpost
Re:UVN800 Sensor does not allow to create a UVI-max or min g
Post by wfpost »
UV-I Sensor
Good finding!
This is a bug (only for uv sensors) that will be fixed with soon coming update 2.4c
lcoulon
Post by lcoulon »
admin wrote: ... that will be fixed with soon coming update 2.4c
Do you know when that new version 2.4c will be released ?
Voler en ULM Multiaxe !
[url]http://www.tousenvol.com[/url]
2.4c has been made available on 28th June. But we are at 3.1c at the moment and the problem shouldn't be there since then. What verison are you using?
If you can't see all your sensors for graphing, please press "save" on sensors page. This populates all seen sensors into the processing path.
