I just moved from the VMware version to a DC01.
On the VMware installation I had created a virtual sensor as in section 2.5 in the manual
t9 tempdiff thb0 sensdiffmaster 1 300
t9 tempdiff th0 sensdiffslave 1 300
this worked on the VMware version but it gives the following errors on the DC01 version:
logger (03.01.2013 22:17:06): processing "sensdiffmaster 1 300" does not return a value string, reason is: sensdiff value position (1) does not match sensor data structure (thb0 234 46 111 10288 10381 2 "temp[1/10C] hum[%] dew[1/10C] press[1/10hPa] sealevel[1/10hPa] forecast"#).
logger (03.01.2013 22:17:06): processing "sensdiffslave 1 300" does not return a value string, reason is: sensdiff value position (1) does not match sensor data structure (th0 98 92 86 "temp[1/10C] hum[%] dew[1/10C]"#).
Am I doing something wrong or is this a bug in the DC01 implementation?
Thanks!
sensdiffmaster/slave on DC01
- Fresh Boarder
- Fresh Boarder
Re: sensdiffmaster/slave on DC01
I have come to the conclusion that sensdiffmaster/slave is broken on the DC01 in version 4.9s.
If anyone has this function working on the DC01, please feel free to correct my conclusion!
Thanks!
Thanks!
