Meteohub on Excito B3
Hardware topics that do not fit in one of the other categories
tervingo
Post by tervingo »
Does anyone know/use the Excito B3 hardware? I am currently running Meteohub on an 'old-and-likely-soon-to-be-dead' NSLU2 and would like to run it on a newer (silent, low-power) server which at the same time is able to act as a Web Server. Seems like Excito B3 with Debian Linux on it could be a good option provided it can run meteohub as a VM, I guess.
Any ideas?
Thank you all in advance
BestRegards
Juan
Re: Meteohub on Excito B3
To be honest, I never heard of the Excito B3 before you mentioned that.
As it is a >300 Euro unit I don't expect major interest in that from the Meteohub users,
so don't expect an official Meteohub port onto that.
tervingo
Post by tervingo »
Well, I'm not particularly interested on the Excito B3 hardware.
What I am actually looking for is some silent server where I can run simultaneosly Meteohub and a Web Server. If I am not mistaken, Meteohub runs its own OS, and therefore in order to run alongside to a WebServer Meteohub should be running on a VM hosted in the silent server. Is that correct?
Thank you in advance for your help
YJB
Post by YJB »
I'm using VirtualBox and one of the virtual machines is running MH. VMware is used by other users, so you should be able to run a Webserver and MH on the same physical hardware
tervingo
Post by tervingo »
Thanks a lot for the info. What I'm not sure of is whether I can run VirtualBox or VMware on a small "silent" hardware (of the eBox, iConnect, DC01 etc. type)
wfpost
Post by wfpost »
forget it! VM on these gadgets isn´t working ... isn´t needed ... and doesn´t make sense at all ...
meteohub comes with a tiny webserver.
What exactly do you want to achieve with the webserver?
Using it for the weather pages?
tervingo
Post by tervingo »
Yes, exactly, I want it for the weather web pages. I didn't know that Meteohub included a small WebServer. God to know! Thanks a lot for the info!
stefferber
Post by stefferber »
I would like to add my own software to meteohub on my dream plug: Using a REST API to control a USB-relais board.
Is there a more detailed description of the metehub software architecture? I could only find one picture on page 10 in the manual v4.7 http://www.meteohub.de/files/meteohub-v4.7en.pdf...
My questions are:
- What kind of web server is used?
- How to plug in my web services?
- Which programming languages are available on a meteohub debian? I could find C, perl, python (any more?)
- How much computing power and memory are "left" for my software?
I would recommend to login via ssh and find out.
If you don't have a meteohub platform to test with yet,
you can install the Meteohub vm and play with it.
stefferber
The reason that I am asking is very simply. I don't want to harm the meteohub software in any way. So how do I adjust the
/srv/www/index.html file for thttpd?
<html>
<head>
<META HTTP-EQUIV="Refresh"
      CONTENT="0; URL=cgi-bin/meteohub.cgi">
</head>
</html>
in order to add a RESTful API?
