Unable to register/purchase
whtworek
Post by whtworek »
Want to purchase meteobridge license, but receive following error message when pressing "paypal" button on meteobridge license screen:
System Message
Error: Connection to PayPal failed. No money transfer has been done
This is unfortunately a bit urgent, as I waited till last day of trial license to try and purchase and would like not to lose my weather station data feed.
I actually seem to get similar message when trying to activate push services to twitter:
System Message
Error: twitter authentication failed: can not get request token
Error: Twitter feed of Meteobridge not yet authorized
Error: Twitter message field is empty
The meteobridge has full network access though, as it is able to log weather data to weather underground without an issue (and has been doing so for 14 days now).
Re: Unable to register/purchase
Please power cycle your unit, by that i takes the newest application stack, which should have the licensing problem solved.
If this is still an issue, please send email to "info(at)meteobridge.com".
I can register to twitter fine. Sometimes first approach fails, second try does work. May be your code is a bit older,
a reboot should also fix this.
albertquiles
Post by albertquiles »
I'm having the same problem with twitter. I started in Firefox and after multiple retries, I switch to IE, didn't work. So, i tried chrome, same thing. I made sure pop-ups were not blocked, I even logged on to twitter in another tab and tested it with other websites. I can't get the pin. Does someone found a solution? BTW, I'm running v 1.8
you need javascript enabled in your browser.
albertquiles
Thanks for your prompt reply. I just check the browser options and it says it has javasripts enabled.
Problem is, that page that shows the PIN does not pop-up?
albertquiles
that is the problem. I can't get the authorization page pop up.
this is what I get: Error: Twitter feed of Meteobridge not yet authorize
I checked again for pop ups and they are not block. I also made sure the browser allows to open in a new window and not a new tab.
MrPippoTN
Post by MrPippoTN »
I've the same problem: I can't purchase the license. When I click on the Paypal button, I get the same message:
System Message
Please help me...
Java scripts and popups are on in my browser.
MrPippoTN
Post by MrPippoTN »
MrPippoTN wrote:I've the same problem: I can't purchase the license. When I click on the Paypal button, I get the same message:
System Message
Please help me...
Solved. And I really don't know how, sorry.
