Meteobridge not loading? **solved**
kalen
Post by kalen »
Meteobridge is not getting any further than the landing page.
kalen
Re: Meteobridge not loading?
Post by kalen »
i have tried restarting but no success....
kalen
Post by kalen »
config.meteobridge.com is also not loading? My internet is working fine. I have the hub plugged in by ethernet.
kalen
Post by kalen »
please help! I cannot even access the client through my computer ethernet port. All I can see on device is the button flashing rapidly.
kalen
Post by kalen »
My hub is fried? I can't even access any part of it at all now. I have tried resetting using the buttons.
server is down. I am working on it.
...and is now back to normal operation.
digiital
Post by digiital »
I'm getting issue tonight, is the server down?
snicko
Re: Meteobridge not loading? **solved**
Post by snicko »
Seeing similar behaviour here.
Stuck at the landing page and can't reach config.meteobridge.com
saratogaWX
Re: Meteobridge not loading? ** NOT solved**
Post by saratogaWX »
I'm having the same issue. Did a reboot and now the TP-Link TL-MR3020 v1 is stuck in the OpenWRT login screen.
Seems config.meteobridge.com gets a 'socket error'.
Please poke the master server so the update can complete and the system successfully restart.
Best regards,
Ken
btw.. http://www.saratogawx.net now has a Meteobridge site
Free Weather website PHP templates and scripts at Saratoga-Weather.org
digiital
Post by digiital »
What did you mean by poke the master server?
saratogaWX wrote: Please poke the master server so the update can complete and the system successfully restart.
saratogaWX
Perhaps restart it... It seems that the automated download of new firmware is broken. Boris will have to handle the fix of the issue. Another person I've been corresponding with has the same problem. Reboot and Meteobridge never comes up, only the default Router interface is active.
digiital
Post by digiital »
I have rebooted a few times, and when I goto the openwrt interface and login, I get the following error: The CGI process did not produce any response
snicko
Post by snicko »
Looks like its working again. My station just came back online.
digiital
Post by digiital »
Mine as well.
BUT! It's not talking to my Weather Networks, and my Live data is empty too.
digiital
Post by digiital »
Ok I'm back online again, I had to (now I'm not sure if this helped or what) but changed mydefault weather station, saved it and waited then selected the correct station again and it started to report my data once again.
digiital wrote:Mine as well.
