Not downloading application stack **solved**
csgregg
Post by csgregg »
I am trying MeteoBridge for the first time on a WL-330N3G. Flashed firmware okay and got into MeteoBridge application first time.
Now after restart, the application stack does not download and I just get the landing page and the fast flashing LED. I have checked the network settings and the device is connected to the internet - I have checked with the OpenWRT diagnostics and have confirmed internet connection. I have also ssh'd into the device and can ping google.com etc...
Looking at the processes running, it is stuck trying to download the image from download.meteohub.com - the /tmp/image.log file contains:
--2013-10-16 02:36:08-- http://download.meteobridge.com/cgi-bin/getmb.pl?paylo
ad=GlMdDmEfDoLiJhAlFeNcJiOdOjIiIhFkNbEbHiOcEpImKcFpAbLgEiDfAjDoBhCkFbAgGpMfIoCj
KhMkObOgCjPaCkIjNcGkMbIgBiOfAoBjIcCpIePgAiPaEoGjIhOkNbPgEiPaBlAjJhFkOeJgAnMaKoD
jNgPpNfHgFiAfAoLiKhAkFbEhFiHeDoFjJhAlMeNdGmMaHlIjKhFkFbLgMiBfEoDjMhCkLaMcHnGaMl
BnJdJpBeHgOlPeBkBnKcCoAbPgCjIfEiAmFcCpCeIcJiIfGlDjJcAlMbKaGmGaGlMoPaLkNbKgEiLf
Resolving download.meteobridge.com... 88.198.202.168, 2a01:4f8:d16:c06::815
Connecting to download.meteobridge.com|88.198.202.168|:80...
and the image.tgz file is zero size.
Any suggestions?
Thanks, Chris
geodementia
Re: Not downloading application stack
Post by geodementia »
It could be a problem with the site that the image is being downloaded from.... My TR-MR3020 is doing exactly the same thing right now, although it has been up and running all day. I just rebooted it (still evaluating whether it works with my WS-2355) and it's now not getting an image - no changes other than a reboot from last time it worked.
If I run a tail -f /tmp/image.log I can see that I'm downloading a zero length image, and the loader is in a continuous loop, always downloading a 0 byte image.
--2013-10-16 20:47:55-- http://download.meteobridge.com/cgi-bin ... JiJfCoFjJh
Connecting to download.meteobridge.com|88.198.202.168|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 0 [application/x-perl]
Saving to: '/tmp/image.tgz'
0K 0.00 =0s
2013-10-16 21:02:11 (0.00 B/s) - '/tmp/image.tgz' saved [0/0]
Might be time to go and do something else and see what happens in the morning :)
Cheers,
Geoff in Alice Springs (AU)
dstanowick
Post by dstanowick »
Suddenly early this morning around 1:00am US Central time my MR3020 started to have this same problem. I rebooted it twice and still have the same issue. It has been running flawlessly for months prior to today.
should work again. Was related to a problem when specifying "stick to Version 2.0" option. But is solved now.
dstanowick
Re: Not downloading application stack **solved**
I did a power recycle and it is still not working.
Just to check, I restarted my network and then my device started working again. That is strange, especially since the device was running with no issues for such a long time. Thanks.
geodementia
Came in this morning and mine's happily running now - downloaded the stack sometime overnight.
Thanks for the fix :D
Geoff
csgregg
Post by csgregg »
Working now - thank you.
Does this happen often?
no, it was a bug in one of the server scripts. As said, issue is solved.
