I've had a meteohub setup for a few years now based on a Davis Wireless Vantage Vue, a wireless ISS and a remote temperature module. It's worked pretty well but I've been having trouble with the rain gauge getting clogged with nearby vegetation.
I moved the ISS to a better place and installed a remote anemometer transmitter so that I didn't have to move the wind gauge too. The problem is that I don't see meteohub pick up the new anemometer info. I've changed the config on the Vantage Vue via the USB connection and the Davis WeatherLink s/w. However, I still don't see the new station show up on Meteohub. I've also got a Vantage console and the new station registered and transmitted just fine on that so I know that it's alive.
From the logs, I see this -
logger (06.11.2013 13:36:14): data logger (version 4.9v, build 1427) started.
logger (06.11.2013 13:36:15): connect station 0 (Vantage via USB serial).
logger (06.11.2013 13:36:15): connect station 1 (RFXCOM via TCP/IP).
logger (06.11.2013 13:36:15): station 0 (Vantage), wakeup sent.
logger (06.11.2013 13:36:15): station 0 (Vantage), internal logger activated.
logger (06.11.2013 13:36:15): station 0 (Vantage), syncing.
logger (06.11.2013 13:36:27): station 0 (Vantage), gettime request sent.
logger (06.11.2013 13:36:27): station 0 (Vantage), time offset of Vantage: 5 minutes
logger (06.11.2013 13:36:27): station 0 (Vantage), eeprom request sent.
logger (06.11.2013 13:36:27): station 0 (Vantage), rain collector size 0.01 inch per tick.
logger (06.11.2013 13:36:27): station 0 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (06.11.2013 13:36:27): station 0 (Vantage), transmitter 2 active as station type (#3) "Temperature/Humidity" mapped to "th1".
logger (06.11.2013 13:36:27): station 0 (Vantage), transmitter 3 active as station type (#7) "Soil".
logger (06.11.2013 13:36:27): station 0 (Vantage), firmware version request sent.
logger (06.11.2013 13:36:27): station 0 (Vantage), firmware version 1.90
The anemometer should show up as transmitter 4. I'm seeing wind0 logged from the sensor data but it just seems to be zero so I'm assuming that's the disconnected ISS wind input.
20131107203852 uv0 019
20131107203900 th0 192 50 0085
20131107203908 wind0 0 0 0 0192
20131107203912 th4 213 43 0082
20131107203912 thb0 217 40 0075 10158 2 10183
20131107203919 th7 250 33 0076
20131107203920 sol0 311 0
Any thoughts or advice?
Cheers!
Scott...
Meteohub not seeing remote anemometer
- YJB
Re: Meteohub not seeing remote anemometer
I would suggest that you check your vantage console again in diagnostic mode and make sure it picks up the wind ISS. It should definitely work with Meteohub:
Ysbrand
logger (08.11.2013 03:00:51): data logger (version 4.9v, build 7016) started.
logger (08.11.2013 03:00:52): connect station 0 (RFXCOM via USB serial).
logger (08.11.2013 03:00:52): connect station 1 (Vantage via TCP/IP).
logger (08.11.2013 03:00:52): connect station 2 (System Data via Plug-in).
logger (08.11.2013 03:00:52): station 1 (Vantage), wakeup sent.
logger (08.11.2013 03:00:52): station 1 (Vantage), internal logger activated.
logger (08.11.2013 03:00:52): station 1 (Vantage), syncing.
logger (08.11.2013 03:01:03): station 1 (Vantage), gettime request sent.
logger (08.11.2013 03:01:03): station 1 (Vantage), no Vantage time offset.
logger (08.11.2013 03:01:03): station 1 (Vantage), eeprom request sent.
logger (08.11.2013 03:01:04): station 1 (Vantage), rain collector size 0.2 mm per tick.
logger (08.11.2013 03:01:04): station 1 (Vantage), transmitter 1 active as station type (#0) "ISS".
logger (08.11.2013 03:01:04): station 1 (Vantage), transmitter 2 active as station type (#4) "Wireless Anemometer".
logger (08.11.2013 03:01:04): station 1 (Vantage), transmitter 3 active as station type (#8) "Soil/Leaf".
logger (08.11.2013 03:01:04): station 1 (Vantage), firmware version request sent.
logger (08.11.2013 03:01:05): station 1 (Vantage), firmware version 3.12
