From the last updated meteo cant send any twit or send info to my page, the system say this:
Error: Twitter authentication failed: can not get request token
Error: Download of template failed (#1):
Error: Download of template failed (#2):
For a device like the Meteobridge with 4MB flash, 32 MB RAM using a SSL equipped version of "wget" on top of the reduced wget that is part of the firmware is going to blow the limit (as there are more things the unit has to work on in parallel). I can't promise a fast solution and apologize for bumping onto a roadblock here. It is the second time since starting with Meteobridge these twitter dev guys invent funny things as they are looking to be bored... hrrr...
...because you are trying to send identical records to twitter, which twitters blocks per default.
You might add a time-stamp to make sure messages are not identical.
