Can the iPhone graphs be used on a website?
As English is not my native language, I maybe have overlooked the answer to my question in this forum, sorry for that.
The iPhone graphs and panel come in very handy on a iPhone.
The panel URL can also be run in a PC browser or copied from "Weather Network" tab by clicking on the computer symbol.
I can use that panel on my websites. Demo http://www.wiri.be/weather2/index.php?p=10-1
As Meteobridge can not generate graphs locally I want to insert the iPhones graphs as a free start for graphing in my Leuven-Template for Meteobridge. Is it also possible to get the url's of the graphs in the same simple way to be used in a normal browser? I can than include that in the install-WiKi.
I understand that this can create "unpaid" load on the meteoplug server, but a subset of the possibillities of meteoplug-graphs can also generate new meteoplug customers.
I use the All-in-one graph to demonstrate. http://www.wiri.be/weather2/index.php?p=65 But that is from the paid meteoplug area and can not be included as an example.
Re: Can the iPhone graphs be used on a website?
Would it help, if there is a template variable that hands over the URLs for the free portions of meteoplug graphing?
admin wrote:Would it help, if there is a template variable that hands over the URLs for the free portions of meteoplug graphing?
That would be an extremely usefull addition.
Thanks for this idea which solves the "no graphing" of Meteobridge.
And if users want to customize beyond the settings they did in their Meteobridge:
They should buy a Meteplug licence and than go to Meteoplug => Define chart
a. The dashboard = *instruments-black
b. The graphs = *iphone-pr-2d or *iphone-tw-2d
At this moment those definitions display an error, so can you please take a look at it?
Error: Expression is no name-value pair: rder_linecolor_rgb"#ffffff"|set_key_font_"Arial,10"|set_xtics_font_"Arial,10"|set_ytics_font_"Arial,10"|set_y2tics_font_"Arial,10"|set_key_outside_le
I will include the descriptions in the WiKi http://wiki.leuven-template.eu/doku.php as soon as the "template variables" are available.
Update has been made, please read here:
http://meteobridge.com/wiki/index.php/Forum
admin wrote:Update has been made, please read here:
NL: Hartelijk bedankt - DE: vielen Dank
I have adapted the template and will test it a few days while adapting the WiKi and releasing the updated scripts.
The new dashboard: http://www.wiri.be/weather2/index.php?p=10-1&lang=en
The Station-Graphs menu choice is now also valid for MeteoBridge users: http://www.wiri.be/weather2/index.php?p=64&lang=en
The availabillity of Imperial and Decimal versions is also very pleasant so the visitor sees the graphs / dashboard in his choosen unit-type.
Thanks again, Wim
marfanuk
Post by marfanuk »
Looking forward to You adding this to Your Template Wim :D
marfanuk
Post by marfanuk »
