offset correction option for outdoor temp sensor **solved**
cmccartney
Post by cmccartney »
Platform: TP-LINK TL-MR3020
RAM: 29364 kB total, 3584 kB free (87% used)
Software Version: Linux/OpenWrt 3.3.8 mips (BE), FW 1.2, MeteoBridge 2.1 (3438)
I have added a "-1.5" correction to the outdoor temp. As you can see below, the 'Live Sensor Data' (25.0°C) is being corrected, but the 'Historical Data, Now' data (26.5°C) is uncorrected and transmitted to the weather networks.
Live DataSensor Signal Metric Data Imperial Data
UV 1 min 2.0uvindex 2.0uvindex
Rain 1 sec rate 0.0mm/h rate 0.00in/h
Outdoor 51 sec 25.0°C 32% (dew 7.0°C, heat 25.0°C) 77.0°F 32% (dew 44.6°F, heat 77.0°F)
Wind 13 sec 0.0m/s (avg 0.0m/s) 135° SE 0.0mph (avg 0.0mph) 135° SE
Indoor 1 sec 21.9°C 42% 1027.0hPa (1007.0hPa) 71.4°F 42% 30.33inHg (29.74inHg)
Historical DataSensor Now
11:36 Today
Sat 15 Yesterday
Fri 14 Month
Mar Year
2014
min max min max min max min max
UV index 2.0uvi 0.0uvi 2.0uvi 0.0uvi 5.0uvi 0.0uvi 5.0uvi 0.0uvi 5.0uvi
Outdoor temp 26.5°C
79.7°F 10.4°C
50.7°F 26.5°C
79.7°F 8.0°C
46.4°F 25.9°C
78.6°F 8.0°C
46.4°F 29.4°C
84.9°F 5.7°C
42.3°F 29.4°C
84.9°F
Re: offset correction option for outdoor temp sensor
Your observation is correct. There was a bug in, which I just removed.
When you reboot the Meteobridge, it should work ok now.
cmccartney
Re: offset correction option for outdoor temp sensor **solv
Thank you for quick responses.
I have entered a temp correction of '-1.5 C'
Station reads 66.2F
'Live Data' reads "-14981.4°C, -26934.5°F"
'Now' data reads "20.4°C, 68.7°F"
user 999
Post by user 999 »
Since your last release is the outdoor temp not correct.
Take a look
Plattform: TP-LINK TL-MR3020
RAM: 29364 kB insgesamt, 4128 kB frei (85% verwendet)
Software-Version: Linux/OpenWrt 3.3.8 mips (BE), FW 1.2, MeteoBridge 2.1 (3447)
Live Data
Outdoor 1 min 9.6°C 80% (dew 6.3°C, heat 9.6°C) 49.3°F 80% (dew 43.3°F, heat 49.3°F)
When i use correction outdoor temp: 0,0 °C
Historical Data
Sensor Now
Outdoor temp 11.4°C
52.5°F
When i use correction outdoor temp: 0,0 °F
Historical Data
Sensor Now
Outdoor temp 10.6°C
51.1°F
Fixed when you do a reboot now.
cmccartney
Re: offset correction option for outdoor temp sensor *solve
Thanks for your quick responses, and on a weekend.
Temp correction appears to work fine, now.
