Meteobridge and WeatherLink
steviebaby59
Post by steviebaby59 »
I am operating a meteobridge with a Davis IP data logger. I'm running into an issue. I need to download records from the data logger in order to import local data to my weather simulator (WXSIM). Unfortunately, the WeatherLink doesn't work well when meteobridge is pulling data on the same IP address.
I see where meteobridge has added a WL upload into it's software. I believe if I can get my data uploaded to WeatherLink via meteobridge, then just download the data from WeatherLink's server instead off the data logger, I could get around this issue. However, I can't seem to get it to work. I have my Select Station tab set to Davis: Vantage Pro2, Vue - IP (WL upload 5 min) with my correct IP address. I have been told WeatherLink should get my data by just doing this. However, when I try to down load data from WeatherLink, it says "No new data to download".
Does anyone else have this problem or understand what I'm trying to achieve?
Re: Meteobridge and WeatherLink
Reading this thread http://www.wxforum.net/index.php?topic=15432.0
it looks to me like the WLIP needs to have the option selected to upload
automatically to weatherlink.
