Help to make a translation to spanish
- josecmorales
- Expert Boarder
How can i help to make a translation to spanish for the webconfig and the outlook (only Davis)
Re: Help to make a translation to spanish
Meteobridge does not send out Davis forecast messages to my knowledge.
To translate the web interface to Spanish...
1) go to "system" tab
2) If not "English" selected as language, select English and press "save"
3) Press "Download Language File" button
4) Edit the new empty language file "lang.new" with a UTF8 compatible text editor and send edited file to "info(at)meteobridge.com". Simply add the Spanish translation for each line after the "::".
5) We will make it part of the distribution then and available as language to choose from in the drop-down menu.
When you want to test your language file, name it "Spanish.lang" and place it into folder "/home/meteohub/" by using ssh/scp. Having done that "Spanish" should be there as new language to choose from.
I have to correct myself, Meteobridge does send out Davis forcast texts. So all I need to put in Spanish is a translation of these definitions. When you send it to "info(at)meteobridge.com" I can include it into the code.
FC texts in English
FC texts in English
char *vantage_fc_rule[] = {
"Mostly clear and cooler."
, "Mostly clear with little temperature change."
, "Mostly clear for 12 hours with little temperature change."
, "Mostly clear for 12 to 24 hours and cooler."
, "Partly cloudy and cooler."
, "Partly cloudy with little temperature change."
, "Mostly clear and warmer."
, "Increasing clouds and warmer. Precipitation possible within 24 to 48 hours."
, "Increasing clouds with little temperature change. Precipitation possible within 24 hours."
, "Increasing clouds with little temperature change. Precipitation possible within 12 hours."
, "Increasing clouds and warmer. Precipitation possible within 24 hours."
, "Mostly clear and warmer. Increasing winds."
, "Increasing clouds and warmer. Precipitation possible within 12 hours. Increasing winds."
, "Increasing clouds and warmer."
, "Mostly clear and warmer. Precipitation possible within 48 hours."
, "Increasing clouds with little temperature change. Precipitation possible within 24 to 48 hours."
, "Increasing clouds with little temperature change."
, "Increasing clouds and warmer. Precipitation possible within 12 to 24 hours."
, "Increasing clouds and warmer. Precipitation possible within 12 to 24 hours. Windy."
, "Increasing clouds and warmer. Precipitation possible within 6 to 12 hours."
, "Increasing clouds and warmer. Precipitation possible within 6 to 12 hours. Windy."
, "Increasing clouds and warmer. Precipitation possible within 12 hours."
, "Increasing clouds and warmer. Precipitation likely."
, "Clearing and cooler. Precipitation ending within 6 hours."
, "Mostly clear and cooler."
, "Mostly cloudy and cooler. Precipitation continuing."
, "Mostly cloudy and cooler. Precipitation likely."
, "Mostly cloudy with little temperature change. Precipitation continuing."
, "Mostly cloudy with little temperature change. Precipitation likely."
, "Increasing clouds and cooler. Precipitation possible and windy within 6 hours."
, "Increasing clouds with little temperature change. Precipitation possible and windy within 6 hours."
, "Mostly cloudy and cooler. Precipitation continuing. Increasing winds."
, "Mostly cloudy and cooler. Precipitation likely. Increasing winds."
, "Mostly cloudy with little temperature change. Precipitation continuing. Increasing winds."
, "Mostly cloudy with little temperature change. Precipitation likely. Increasing winds."
, "Increasing clouds and cooler. Precipitation possible within 12 to 24 hours possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 12 to 24 hours possible wind shift to the W, NW, or N."
, "Increasing clouds and cooler. Precipitation possible within 6 hours possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 6 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation ending within 12 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation ending within 12 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possible within 24 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation possible within 24 hours possible wind shift to the W, NW, or N."
, "Clearing, cooler and windy. Precipitation ending within 6 hours."
, "Clearing, cooler and windy."
, "Mostly cloudy and cooler. Precipitation ending within 6 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation possible within 12 hours. Windy."
, "Increasing clouds and cooler. Precipitation possible within 12 hours, possibly heavy at times. Windy."
, "Mostly cloudy and cooler. Precipitation ending within 6 hours. Windy."
, "Mostly cloudy and cooler. Precipitation possible within 12 hours. Windy."
, "Mostly cloudy and cooler. Precipitation ending in 12 to 24 hours."
, "Mostly cloudy and cooler."
, "Mostly cloudy and cooler. Precipitation continuing, possible heavy at times. Windy."
, "Mostly cloudy and cooler. Precipitation possible within 6 to 12 hours. Windy."
, "Mostly cloudy with little temperature change. Precipitation continuing, possibly heavy at times. Windy."
, "Mostly cloudy with little temperature change. Precipitation possible within 6 to 12 hours. Windy."
, "Increasing clouds with little temperature change. Precipitation possible within 12 hours, possibly heavy at times. Windy."
, "Mostly cloudy and cooler. Windy."
, "Mostly cloudy and cooler. Precipitation continuing, possibly heavy at times. Windy."
, "Mostly cloudy and cooler. Precipitation likely, possibly heavy at times. Windy."
, "Mostly cloudy with little temperature change. Precipitation likely, possibly heavy at times. Windy."
, "Increasing clouds and cooler. Precipitation possible within 6 hours. Windy."
, "Increasing clouds with little temperature change. Precipitation possible within 6 hours. Windy"
, "Increasing clouds and cooler. Precipitation continuing. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation likely. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation continuing. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation likely. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds and cooler. Precipitation possible within 6 hours. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 6 hours. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds and cooler. Precipitation possible within 12 to 24 hours. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 12 to 24 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possibly heavy at times and ending within 12 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possible within 6 to 12 hours, possibly heavy at times. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation ending within 12 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation possible within 6 to 12 hours, possibly heavy at times. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possible within 12 hours, possibly heavy at times. Windy.", "FORECAST REQUIRES 3 HOURS OF RECENT DATA"
- josecmorales
- Expert Boarder
Ok thanks, im going to start now
